2008 F-150 Transmission Slip??
Old 08-10-2008, 11:04 AM
MAK's Avatar
MAK
MAK is offline
Finally had to get rid of the 250 with the death wobble, was a great truck until that happened! Settled on F-150 and, according to the wife, am having some issues already at 4500 miles.
I don't drive it too much but she reports some sort of slip/surge when going up or down small inclines, has happened three times.
She describes it like throwing the truck in neutral for a brief moment the putting it back in gear.
Anyone else experience this issue?
Old 08-10-2008, 01:09 PM
vanman250's Avatar
vanman250
vanman250 is offline
Did you check you fluid level?
vanman250
Old 08-10-2008, 06:55 PM
RISUPERCREWMAN's Avatar
RISUPERCREWMAN
RISUPERCREWMAN is offline
This is a common occurence, I have it on my 2007! Had it checked out, & they could not find anything! It's like a glitch in the software programing, it will only happen at speeds of 25 MPH, & in heavy traffic, or slow conditions. Way to alleviate it is to push in the OD button to the off position, so that the tranny shifts more smoothly & crisp in heavy traffic & slow conditions! It's just the way the tranny is...........
Old 08-11-2008, 02:47 PM
F150BOB1's Avatar
F150BOB1
F150BOB1 is offline
I have the same problem with my 08 S-Cab. They are coming out with a software update for the transmission. I purchased my truck in January and have to bring it in for an update. Back in March, the update was not ready. This should fix this problem, I hope ??
Old 08-11-2008, 04:08 PM
Slvr 2008 SS SC's Avatar
Slvr 2008 SS SC
Slvr 2008 SS SC is offline
Do you know if this is a warranty recall?
Old 08-11-2008, 04:45 PM
fitz888's Avatar
fitz888
fitz888 is offline
My 08 does the same thing its a delay in the down shift not a slip though.Dam computers.
Old 08-11-2008, 06:14 PM
Bigtony4's Avatar
Bigtony4
Bigtony4 is offline
My 04 does it. The dealer said it was beacuse the transmission goes into a freewheel mode when you are not touching the gas. Then when you step back on the gas it clunks back into whaterver gear it needs to be in. I feel it when I don't come to a complete stop and take off.
Old 08-11-2008, 06:31 PM
Oldguy4's Avatar
Oldguy4
Oldguy4 is offline
My 2007 Screw Fx4 does it too. The first time it happend it felt like a slip but then the next couple of times I realized it was having trouble deciding which gear to be in. For me it always happens when I come around a corner in town about 15 mph then go to accelerate up to 25.
Old 08-13-2008, 06:47 PM
08screwfx4's Avatar
08screwfx4
08screwfx4 is offline
Mine does the same thing, but when I'm in heavy traffic or going slow around town I just hit the O/D button and it runs just fine.
Andy
Old 08-13-2008, 07:05 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
no idea what you guys are talking about
06 FX4 Supercrew
Old 08-14-2008, 12:05 PM
e16wtd's Avatar
e16wtd
e16wtd is offline
My 08 S-cab had a bad vibration when re-accelerating at highway speeds. The dealer said this was normal for the truck(I don't think they road tested it) but it went away after 8 or 9k. I am not sure if my recent service corrected an issue or if it adjusted on its own...
Old 08-14-2008, 02:29 PM
slc10844's Avatar
slc10844
slc10844 is offline
06 FX4 Supercrew
I think it is about 3-4 shift flare, 25-30 mph, light acceleration. Affects 07 & 08 between certain build dates. Ford has a TBS on reprograming the computer.
Old 08-14-2008, 03:53 PM
RISUPERCREWMAN
Do you know for sure if there is a TSB? or know of it's # or copy? I would like to show it to my dealer?..........
Old 08-14-2008, 06:50 PM
slc10844's Avatar
slc10844
slc10844 is offline
TSB 08-14-3
5.4L 3V / 4R75E ONLY—BUILT BETWEEN 12/4/2006
TO 5/20/2008—ENGINE RPM FLARE DURING 3-4
UPSHIFT UNDER LIGHT THROTTLE ONLY
FORD: LINCOLN:
2007-2008 F-150 2007-2008 Mark LT
Old 08-14-2008, 08:02 PM
RISUPERCREWMAN
TSB 08-14-3
FORD: LINCOLN:
Thanks now I have something to show my dealer!..............
Quick Reply: 2008 F-150 Transmission Slip??
