Is it time to trade
Is it time to trade
What would you do? I have 2003 F250 4X4 extened cab with the 5.4L in it. It has around 65000 mile and I have had to replace the front rotors and pads at 37000 and shocks, then driver side ball joints at about 42000. I thought the rear main seal was leaking and changed that around 62000. Now it is at the dealer to fix what I thought was the same oil leaking from the rear main again, but have been told it is the driver side head gasket and that the head is fine but the block is not.$$$$$$$ So do I trade it off once fixed or keep drivin the gas guzzler. I only get at best 13 MPG. Anyone had these problems or am I just lucky????
curious how the dealership has determined the block is buggered..
have they actually pulled the head off ?
as for 13MPG, nothing u can buy new in a SD lineup will give much better then that with the current new emissions regs..
do you own the truck in question ???
if u do the repair bill once paid would be it, but a new truck would mean payments every month.. kinda look at it as a monthly "repair bill"... is ur current truck costing u anything like a monthly new truck payment ???
if ur old truck costs as much to own as something new/financed, then i'd be looking at a NEW truck and cut ur loss's.. BUT if ur current truck is more or less relaible (save for the odd breakdown) then i'd ride this repair cost out and see what happens...
p.s. either way u have to pony up for a repair on ur truck, as it wont be worth anything with a bad engine...
My recommendations are:
1. Don't have the dealership do the repairs because you are going to pay too much. Find a local shop with a good reputation and you will save $$$.
2. If the estimated repair cost is $2,000 or more, then I would replace the engine with either a new OEM or remanufactured engine (Jasper). It's easier and cheaper to just replace the engine than to pay the labor hours to tear it down to the block.
Best success!
Best success!
Any repair is less than the sales tax and registration on a new truck.
So if you like the truck and it suits your needs it is always worth fixing it and keeping it.
If you use it for buisness there might be some investment tax credits and new car tax credits worth looking in to, but it is still cheaper to keep her.
...at .002 - I would tell them that a set of new Fel-Pro performance head gaskets would be fine, thank you!!! That tolerance is ridiculous in a mass produced item like a 5.4 SOHC engine and is virtually impossible to achieve in a USED engine that has seen temp variations from plus several hundred degrees down to minus many more
I had a 2002 f-150 with the 5.4 never had any trouble until one day on the way home (lucky on a couple miles) blown a spark plug out on the drivers side (factory plugs never been replaced) striped the threads, got it fixed and had new plugs put in and then a few months later blown another spark plug on the passenger side. That just give me a reason to trade for the f-250 psd that i had been wanting. At the time i still owed 2 years on the f-150, I got a good deal on trade i am only paying a little more a month and for only 2 more years for an 06 F-250. My sister on another note has a 03 F-250 5.4 FX4 and has never had any problems at all with 135,000 on it.
