Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Oil in intake
Old 05-22-2002, 11:09 PM
RdRover43's Avatar
RdRover43
RdRover43 is offline
Oil in intake
Anybody know why I have oil in the air snorkel tube from the air cleaner to the throttle body on my '01 lightning? Could this be a crankcase ventalation problem?
Old 05-26-2002, 07:51 AM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
Oil in intake
Its usually crank case ventilation. Sometimes piston blow-by is the root cause.
Old 06-02-2002, 09:37 PM
junehhan's Avatar
junehhan
junehhan is offline
Oil in intake
Next time you change the oil, try not to top it off and see if the problem stops. Adding a crankcase breather cap will help keep oil out of the intake, but then you'll need a custom chip burned for it.
2002 True Blue SVT Lightning
-all stock and will stay stock
Amsoil Dealer
Old 06-04-2002, 11:14 PM
00BlackLightning's Avatar
00BlackLightning
00BlackLightning is offline
Oil in intake
Someone (JeffsLightning) has posted some pic of oil filter similar to what is used on an air compressor, splice into the vent line.
