Towing capacity and GCWR for a 1993 F350 dually
My owner's manual doesn't list the truck I have so I can't get the towing/carrying capacities. Also, the Ford research dept. told me that they would send me all the info but all they sent was a towing brochure for 2002 Fords. Here's what I have: 1993 F350 regular cab dually, auto trans, 460 engine, 4.1 axle. I have been pulling a horse trailer, which when loaded with horses and gear, weighs 5000 pounds. I use a weight distributing hitch. I have put a cabover camper on the truck and the camper weighs about 2100 pounds when loaded. The truck has a GVWR of 10,000 pounds and weighs about 8200 pounds with passengers, gear, and camper. I want to make sure that I can pull the trailer with no problems now. I'm certain I can, but I would like to get the numbers anyway. Does anyone know what the GCWR is for my truck? Any help would be appreciated.
on
I have a 89 F250 which is equipped like yours(460, C-6, 4.10's, tow pack with super cooling) my owners manual states a GCWR of 18,500 lbs. and a max trailer weight of 12,500 lbs. You should be close to the same. The towing capacity between an F250 and F350 are usually within a couple hundred lbs. the big differance comes in the weight you can carry in the bed of the truck, with the F350 naturally being able to carry more weight. Deen
Haestings
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
20
10-20-2015 03:25 AM
lasitter
12-19-2009 11:16 AM
