Problems with the site? Webmaster?
#46
#47
on
I did a little digging and saw what I thought was a problem with the source code on the page with the Superchips Ad - I opened a problem complaint with the admin.
I got this response back from the Webmaster as to how we should deal with the problem:
First make sure you are logged off… then clear ALL your cookies/cache, …then run-disk clean up check ALL and dump, then de-frag you HD restart and log in…ALWAYS log off when done.
I don't think I've ever logged off... I don't know how I don't think
j
#48
#50
on
#52
#53
Yes Penn Dick has hit the nail right on the head!
One of the MAJOR problems that is causing all these things is all this ANIMATED ADVERTISING GARBAGE that has been put on all the pages. It is protocoled to open first. And with most of our computers, unless you have one that is less than two years old, that animated junk is going to occupy your active memory so much that it will not be able to work fast enough to bring up the entire page.
Take a look next time and see if the pages you are having problems with or you are getting the error cue on don't have some type of video type animated advertisement running on it.
Only two things are going to fix that: less junk occupying up a page on the site or you buy something to give you computer more active memory (the part of it that runs all you open programs while you use the computer).
At least that is what I was told by oneof my best friends who is a Programming and Software Manager for EDS and knows quite a bit about computers.
#54
Julie's got it ....
also updating java script programs will help 'some'...
this 'new' stuff (junk) is now all over evay with ads everywhere...as these web programmers 'make busy work' to justfy their job.... most systems don't have enough memory... and the 'new' vista program EATS memory...
#55
Received 1,353 Likes
on
