I need to do a brake job in my dads 2002 diesel f250. I was going to get the calipers at Napa for 75 but also found some made by fenco at Auto Zone for 59.
Is there any difference? should I use one instead of the other?
Why do you need calipers? A good set of pads and either refinished or replacement rotors and if your bored a brakefluid flush should be all the brake job needed.
