92 & newer body mounts
92s are different from 99s. The bushings just ahead and just aft of the rear axle are some goofy conical deal that look nothing like the puck bushing used elsewhere and all around in later vans. I can't make sense of this odd bushing but it appears the biscuit goes on the inside of the open channel frame member. Even the best maintained early E150 I've seen (not ours) has bushings that look like this (ours) -
My guess is the cone looks clean because the body sank onto the frame over time then lifted when I installed new shocks with helper coils aka Monroe load adjusting Sensa-Tracs.
I'm surprised no one has chimed in with aftermarket part numbers known to fit. I'd take a puck from your open frame to a local 4X4 shop and see what's the closest fit in aftermarket bushings in your choice of material.
Sixto
93 E150 Chateau 5.8 185K
Sixto
I found this ebay listing for hardware for early broncos that looks similar. When I search for the bushings that would correspond, everything looks round like the others. Any chance that the rubber bushing is the same, or similar round bushing that the others use?
http://www.ebay.com/itm/early-bronco-66-77-body-mount-hardware-32-piece-ford-new-/121106445493?hash=item1c3281b4b5&vxp=mtr
If it does use the same round bushings, here are some OEM takeoffs from Bronco Graveyard that should fit...can't beat the price at $3.00/pair!
http://broncograveyard.com/bronco/i-...-bushings.html
What does the lower retainer look like??
Bruce
Bruce
E350 Body Mount Bushings
Early Bronco 66 77 Body Mount Hardware 32 Piece Ford New | eBay
Bruce
Bruce
Did you ever find the right body mounts? I have a 2005 E350 and running into the same issue.
Thanks,
Tom
ryanhablitzel
01-16-2013 11:29 PM
tabijan
12-14-2012 09:32 PM
blk dog
11-23-2010 12:23 PM
