painting a bumper cover?
Yes it is possible. 320 or 400 grit should be fine. It will take some time, but anymore agressive and you have to sand out scratches. You will then need primer and paint designed for use over plastic (some have flex addative added, some you have to add it yourself) To match your truck, you should do it in base coat clear coat, but can also be done with laquer and clear coat or straight enamel.
FoxyFordGirl514
Appearance & Dress-Up
18
10-20-2005 04:38 PM
