2006 Warranty to run out.
I have a 2006 F-150 2 WD standard cab V6 Automatic with trailor tow and limited slip differential. I have about 24 K on the truck and my warranty will run out in June. Is there something on these trucks that I should have checked out befor the expiration. I have had it back to the Dealer for an oil filter adapter leak and a leaky rear shock and some noise from the fan motor..all repaired or replaced. Just looking for advice.
when was your truck built?
pre July 2006 - 3yr/36k bumper to bumper
post July 2006 - 3yr/36k bumper to bumper
......................5yr/60k powertrain
Ford ESP or nothing
the Ford ESP is a OEM factory warranty that rides ontop of the 3yr/36k bumper to bumper warranty.
You drop the truck off, it gets fixed, you pay the deductible (if you have one) and drive away...non-Ford warranties can and will fight you for every little thing and they have some of the strangest clauses you'll ever see.
Most non-Ford warranties are completely worthless and your money was wasted.
Ford ESP or nothing
