Found another under hood tool box today.
Well, that is just PERFECT. You knew "someone" in here was looking for it, and you sell it in 1 day to the first person who waved money in front of you. I bet the one you just sold had a WORKING latch, whereas the one you are offering me has a broken latch, right? Send me a PM and tell me how much you are asking.
Kick panels I need in CANYON RED. Both sides.
That kind of tone is uncalled for. I even offered to hook you up with the one out of MY OWN truck because I felt bad and this is the way you respond??
I think I'm just going to keep the one I have.
MY tone? You better look at all of your own posts, Stosh, almost ALL attitude, so I figured that is the way you liked to communicate.
I have asked you for parts NUMEROUS times in here (and PM) when you found something that you wanted to sell that you either found in the junkyard that you didn't need or had "numerous in storage" and you NEVER followed through! Off the top of my head I can think of the underhood tool box, kick panels, transmission cooler, and a steering column. Each time you told me you either "had it" or "could get it" and promised to get back to me, but never did. I have since bought all of the items listed above except for the kick panels and tool box from somebody else.
I don't use "broken" pieces on my truck, so you can keep the toolbox.
Scrubbed and painted the bracket, the coolant/washer fluid jug is already in a dumpster as it was trashed, and will clean up the toolbox itself tomorrow. Will post the "after" pictures...might be surprised. There are no holes in this one, like the other one I found (reference post #3, I think) and although the latch is missing, didn't really notice it until sometime later.
EOTZ1046100A .. Storage Compartment-Tool Box / Mounted in Engine Compartment / Obsolete.
No Ford Dealer or obsolete parts vendor has any.
EOTZ10461A08A .. Mounting Bracket / Obsolete
E1TZ10461A10A .. Retainer / Obsolete
E1TZ10461A12A .. Retainer for Mounting Bracket / Obsolete
GREEN SALES CO. in Cincinnati OH has THREE: 800-543-4959.
SHOWALTER MOTOR CO. in Vernal UT has ONE.
No other Ford Dealer or obsolete parts vendor has any.
Original Application: 1980/84 F100/350 / 1980/85 Bronco / Use without auxillary battery.
Y'all know of course that Ford also offered for F Series Trucks: "In Cab Caddy Organizer: With or without the rifle rack.
D8TZ1046100A .. In Cab Caddy Organizer-Without Rifle Rack / Obsolete
D8TZ1046100B .. In Cab Caddy Organizer-With Rifle Rack.
AUBURN MOTOR SALES in Auburn IN has ONE.
Be prepared, this dealer wants "top buck" for his obsolete parts.
No one else has any.
Stosh,
That's such a cool find! I know we try to keep as much factory in our ol' fords as possible, but if a guy really wanted something 'sort of' like this for under the hood, would an old .50 cal military ammo can work in the original tool boxes' stead? I'd think welding some mounting brackets to the can to hold it to the wall and also hold the overflow/washer fluid res. might work. Then line the can with soft foam so the tools don't rattle as much. My disadvantage is I have to haul alot of hay with my short bed and a truck box takes up bed room, so it would be nice to have a few important tools tucked out of the way.
Still an excellent find though!
#28
Stosh,
#29
I have seen that done before and wouldn't hesitate to do it.
There are several unused mounting slots on the fender and I really don't think an additional support would be necessary unless you are going to put a lot of weight in it.
You could remove the washer reservoir and use the mounting tabs as a guide to drill out the can.
Ammo cans are cheap and very sturdy. I say go for it and post some pics.
#30
I've been thinking of fabing a faux factory toolbox for my F250 but I think I'll devide mine up for half aux electrical junction box (relays, fuse panel, buss connections) and half storage (inverter maybe, nice to have 120V AC).
