DR/Icon 4.5" Installed...
Got a killer deal on a used kit; its been sitting in my basement for a couple months now and I finally found some time to install it...
The install was pretty simple and took me and my Dad about 5-6 hours to put on. The radius arm brackets were the hardest part but wasn''t too bad.
Also for the rear I still have F350 blocks and an AAL... didn't get to install the 5" blocks because the u-bolts I got were too short (probably because of the overload springs)... will have to get a set ordered up this week.
I probably won't go much higher than this... 7" would be HUGE! lol
I have some 1" TEI spacers from Icon and may put those on in the future.
Thanks! The 2" more really makes a difference in the stance. This setup also addresses the castor issue and improves the handling of the truck over any leveling kits. Even with castor cams I didn't care for the way my truck drove with the 2.5" kit... I'm probably just picky though.
Wow, fellow reg. cab owners are coming out of the woodwork lol.
I think 4.5" is about the perfect height if you want a good stance and use the truck for work a lot... not too high to get in/out of or load stuff.
That said... it seems lifting is almost an addiction and most guys end up going bigger after a while.
