Int. Door Panels for 88 Bronco
Looking for what year or years of door panel are useable in the 88 bronco. Also looking for any aftermarket interior resources. The scrapyards are fine and I've looked locally but I figure the panel is likely to be the same for most of the 86-90 F-line and the Bronco. Any suggestions or experience would be appreciated.
Any ford Truck or bronco from 1987-1991 will work. THe JC Whitney door panels look good in the catalog, but the clips that hold them on go through the outside. Which looks nothing close to factory. Whereas the Ford Panels the clips went on behind the panel and held in place just fine.
1988 F-150, SWB, 5.0 EFI (formerly 4.9 EFI), M5OD 5 speed, 3.08 gears, Summit shorty truck headers, Custom built Flowmaster exhaust system. Force 4 LP6000 lightbar, Federal signal PA-300 100 watt siren, Icom IC-V100 50 watt mobile radio.
1965 F-100 (just purchased 1/18/01), SWB, 390, C-6 auto. Dual exhaust, Not much else to do to it.
Can see both below.
[link:www.geocities.com/hotrodford_88/|Hotrodford_88's Webpage]
Can see both below.
