Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V10 (6.8l)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Modular V10 (6.8l) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 02-21-2009, 05:01 PM
fordmdb's Avatar
fordmdb fordmdb is online now
FTE Sponsor
fordmdb is gaining momentum as a positive member of FTE. fordmdb is gaining momentum as a positive member of FTE.
99 2V Dyno'd
Dyno'd the 99 today, auto, 194k miles F350 ,4x4 , 285 tires...
First graph shows stock vs an 87 tune. More power and better torque lockup strategies.
Second graph shows how a stock tune does not use power enrichment during WOT.
We will have some intakes and Y pipe dyno runs next now that we have established a base line with stock pcm. The truck is 100% stock from front to back... with 3.73 gears. Sorry for the bad scans... have to get a new scanner.
1999 V10 F350 pictures from rides photos on webshots
__________________
www.5startuning.com email me here: mike@5startuning.com
843-667-3595
See Group Buy here http://www.ford-trucks.com/forums/90...group-buy.html
SCT Custom Tuning Dealer / Level 4 Engine Controls / In-House DYNO
2008 V10 F350 SC ,2005 F150 5.4L , 2002 GT Stang , 2008 Ford Edge, 1999 V10 F350, 2003 F250 5.4L V8, NEW! Project Tow Haul 2000 F250 V10
  #2 (permalink)
Old 02-21-2009, 05:52 PM
saggys saggys is offline
saggys is starting off with a positive reputation.
I cannot wait for the Y pipe dyno runs. Are you going to do any with a CAI?
I just purchased a Volant which maybe a waste of money but the price was great.
Thank you for sharing your results as I have the same year truck and can build from your runs. Your tuner has suprising results!
  #3 (permalink)
Old 02-21-2009, 07:26 PM
fordmdb's Avatar
FTE Sponsor
Hi saggys
For sure we will be dyno'ing some cai along with filters and such. That stock run was the best out of 5 runs. Other stock runs varied 162-166 HP... it was not consistant at all. Did 2 runs with the 87 tunes and they were .6 hp of each other...
Mike
__________________
843-667-3595
  #4 (permalink)
Old 02-21-2009, 08:24 PM
Stumpalump's Avatar
Stumpalump Stumpalump is offline
Stumpalump is starting off with a positive reputation.
What exacly are you changing with this tuner? Is this a programer you plug in? Does it work on E350's like my 02 Van?
__________________
1979 F350 4x4 SC 460 ci SM465
2008 Ford Edge 265 hp 3.5L Daily driver
1951 Ford 8N Tractor
2002 E350 4x4 V10
  #5 (permalink)
Old 02-21-2009, 08:49 PM
Monsta's Avatar
Monsta Monsta is offline
Sit. Stay.
2005 Ford Excursion
Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of
Nice! 17hp with some minor tweaking. Sounds like there's more lurking in that ole 99. Look forward to the Y-pipe run.
Rep to ya! This kind of data (proof) is SO needed!
__________________
Ken
Cats; nasty creatures...
  #6 (permalink)
Old 02-21-2009, 08:57 PM
fordmdb's Avatar
FTE Sponsor
Quote:
Hi stumpalump
Stategies related to fueling ,timing and many tans related functions.
This is SCT X3 programmer that plugs into OBDII port and reflashes PCM.
It will work just fine on your E350 Van...
Mike
__________________
843-667-3595
  #7 (permalink)
Old 02-21-2009, 09:02 PM
fordmdb's Avatar
FTE Sponsor
thanks Monsta
Peak to Peak was 17 hp, other areas are a tad bit more 20-23 hp.
Thanks for the rep....
Mike
__________________
843-667-3595
  #8 (permalink)
Old 02-21-2009, 09:06 PM
Monsta's Avatar
Sit. Stay.
2005 Ford Excursion
I know the truck has 194K+ miles but I wasn't expecting such a large difference in RWHP and the 275 advertised. I figured a 20% loss for driveline friction. Think the engine may have lost compression over the miles?
__________________
Ken
  #9 (permalink)
Old 02-22-2009, 06:07 AM
fordmdb's Avatar
FTE Sponsor
Most of the drive train loss is normal , between the auto trans, transfer case, axle and larger tires. It takes hp to turn those. Also, a dyno jet will read higher as well (they engineer a plus factor in when manufactured). We try focus on controlled conditions with before and after gains. The truck drives and runs well for 194k miles. I am not sure about the compression. Did a plug change last week and all plugs are burning clean. But on the street you can tell the stock programming is lacking compaired to a tune with hp/torque gains and better shift and torque strategies.
__________________
843-667-3595
  #10 (permalink)
Old 02-22-2009, 11:43 AM
bro460 bro460 is offline
bro460 is starting off with a positive reputation.
That is the programmer I would like to buy. Nice to see that there is actually an improvement. Now I have to buy one. Intresting to see what the exhaust and cai dyno run will be. I have almost the same truck just c/cab w/35in tires.
  #11 (permalink)
Old 02-22-2009, 01:09 PM
dzdiggin'dude dzdiggin'dude is offline
dzdiggin'dude is starting off with a positive reputation.
Does your tuners do any diagnostics, also are they programed for my specific eng., tranny, gearing, tires, and other mods?
  #12 (permalink)
Old 02-22-2009, 01:19 PM
Monster-4's Avatar
Monster-4 Monster-4 is offline
Who? Me?
2000 Ford F-250
Monster-4 has a good reputation on FTE. Monster-4 has a good reputation on FTE.
Nice! Can't wait to see the y-pipe runs.
__________________
Mike
2000 F-250, SC, SB, 4X4, Lariat, 6.8 V10, Auto, 3.73, Ford Racing headers, SCT X3 93 Performance tune by 5 Star Tuning
  #13 (permalink)
Old 02-22-2009, 01:30 PM
SID297 SID297 is offline
SID297 is starting off with a positive reputation.
Any plans for a PI swap? It would be interesting to see that difference.
  #14 (permalink)
Old 02-22-2009, 02:33 PM
Krewat's Avatar
Krewat Krewat is online now
Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future
Nice work Mike
Keep the info coming.
The hell with it, this is now a STICKY.
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #15 (permalink)
Old 02-22-2009, 04:30 PM
fordmdb's Avatar
FTE Sponsor
Quote:
thank you bro460,
We will be posting results shortly. Give me a shout if you want to talk shop.
thanks Monster 4 I will be sure to let you know.
Mike
__________________
843-667-3595
Tags
2v , 54 , 68 , 99 , dyno , f250 , f350 , ford , headers , heads , pi , run , sct , sd , tune , v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
