460 in place of 351M 1978 460 Flywheel?
I am working on replacing a 351m in a 79 F-250 to a 460 the 460 is a 1978 motor. I am planning on keeping the manual transmission. I need advice on what I need for a flywheel. I'm fairly sure that the bell housing will bolt right up. Im just unsure where to get the right flywheel ( balanced-unbalanced) (and off what motors or years could I rob a flywheel?) Any help greatly appreciated.
1979 is the cutoff so you need a neutral balance flywheel for a 1978 engine. a 390 flywheel should work fine if you use a 390 starter, or you can spend more and get the proper 460 flywheel. youll need a diaphram clutch set because the 3 finger clutch set wont fit without a spacer between the bellhousing and block. the 351m bellhousing is shallower than a 460 bellhousing... youll also need swap motor mounts... cheap ones can be had for about 90 dollars from summitracing.com
if it is a manual transmission the with a removable bellhousing the 351M and 460 bell housings are the same as far as flywheel goes they used the 460 motor up to 95 i think but if you have the 400M (a 351M block with a windsor crankshaft i think that the flywheel you have will bolt up and work on the 460
There was both, after 79 was externall balanced, earlier are internally balanced.
I never can figure out which one 79 is though
I pulled a bellhousing off a 2wd camper special with a 460 and the NP435 and it was exactly the same depth as my 400 bellhousing that I already had. I've been told the spacer thing more than once though, I just havent seen a bellhousing that was the wrong depth yet.
The easiest solution is to get a flywheel off a newer externally balanced 460 and have it neutral balanced at a machine shop. You could buy it new from L&L for too much money, or you could use a 390 flywheel which are plentiful, but sometimes people end up with starter nightmares on the 390 flywheel.
Good luck and keep us posted on how it turns out.
Kevin Thayer
17
01-23-2014 11:16 AM
mositso
Engine Swaps
13
03-07-2010 07:30 PM
jetblack06
02-12-2010 07:42 AM
ford_boy_1996
11-13-2007 08:15 PM
