i think i need shocks
I have an 02 F250 SD, ever since i started plowing this winter i noticed after i took the blade off the truck rides like a horse, So i figured its time for shocks, i called Ford they want 180 a piece for the front shocks i dont know if i need to do the rear ones, should i got OEM or aftermarket does it matter? I'll do em myself its an easy job. Trucks got 70k on it am i jumping the gun or is it due? I was told the truck will ride even worse for a couple k miles before the new shocks set in, is this true? Also anyone recommend some good shocks that will help the truck ride better or is that a lost cause?
Another vote for Bilsteins. Shocks don't affect ride height. And yes, after 70k your stockers are long gone; they will feel like a wet noodle when you take them off. No jacking necessary for shock swap - just turn the wheels lock to lock for easier access on the bottom of the front shock mounts. Get Bilsteins and no more worries!
I just put the Bilsteins on my 04 250 and, as it turns out, the stock shocks were not blown at all. No oil leaking and hard as a rock with 81,000 miles! (The dealer told me I needed new front shocks?)
I have been plowing with my truck since day one and have hauled lots of heavy stuff.
IMO - It rides only slightly better with the Bilsteins. It seems a bit tighter in the turns and firmer in general.
Install time is under one hour. I left the bands on rears and holes lined up perfectly. BTW - I think the torque is 78 for fronts and 48 for the rears?
For $250 delivered its not that big a deal and you will need them eventually anyway. Hopefully, it will always ride like a truck...
