coolant leak on 4.6 only when below freezing
I have started to notice a small amount of anti-freeze on the ground in the morning after a cold night. It is where the bottom radiator hose returns to the block. The clamp apears tight and I havn't tried to get under it yet to check the fitting that bolts to the block. Why would this not leak while the engine is running either while cold or hot and show up later. I have looked under there right after engine shut down and don'ty see anything leaking. I also have the correct coolant level. Any help?
As the radiators get old, the side tank seals often don't hold fully tight. I've seen it in the past on other Fords in cold weather. The cold must shrink the seal enough to allow a slight leak on an old rad. You can take the rad to a rad shop and have them re-crimp the tanks on tighter or replace the whole rad if it really bothers you. Or just ignore it, as it rarely amounts to much.
-Dave
-Dave
Yeah the amount is unnoticable as for fill level.. but I am not seeing it under the rad it's at the bottom drivers side of the block where the lower rad hose is connected . It's real hard to get a good look at where the fitting meets the block. I'm thinking why isn't it leaking under some pressure.
