Using a Rotunda 78-0100 Tach & Time meter
Old 08-04-2011, 08:20 PM
Tom D's Avatar
Tom D
Tom D is offline
OK, I found one by searching Gogle. They show a V765-01 and a V765-03. The -01 is $192. Is that the one I want?
Tom
Old 03-12-2014, 07:54 PM
Chevy_Eater's Avatar
Chevy_Eater
Chevy_Eater is offline
Old 03-12-2014, 08:41 PM
speedwrench72's Avatar
speedwrench72
speedwrench72 is offline
with ferret adapter timing is set at 2000 rpm, you must use a standard timeing light that has tach built in and a **** to adjust the advance of the light to line up the timing marks, then look at the number on the advance **** to see your current engine timing. at idle my engine is at 12.5btdc and when reved to 2000 it moves to 6.5 btdc this timing change is normal.
kr98664
'80-'86 HOWTO's
22
02-17-2024 10:15 AM
Deerfield411
1999 to 2016 Super Duty
08-18-2017 09:33 PM
ctubutis
Testing.....
08-15-2017 11:03 PM
Aidanw
40
01-14-2017 12:04 PM
Codeseven
06-17-2016 12:30 PM
Quick Reply: Using a Rotunda 78-0100 Tach & Time meter
