Offroad & 4x4
Theoretical question about lockers.
Old 02-03-2009, 01:06 PM
cyclegrip's Avatar
cyclegrip
cyclegrip is offline
Lets say I only have enough money to buy 1 locker. Should I put it in the front, or the rear for better traction?
Old 02-03-2009, 02:53 PM
BradyCouchman's Avatar
BradyCouchman
BradyCouchman is offline
i would say the rear....many stock lockers you have to lock the back before you can lock the front...
Old 02-03-2009, 03:06 PM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Token Redneck
Back. Why are you looking into a locker? What are the specs on the truck?
78250crewcab4x4's Avatar
78250crewcab4x4
78250crewcab4x4 is offline
It depends, give us more info, like vehicle, type of locker and whats in the diff. now
Old 02-04-2009, 06:20 AM
rebocardo's Avatar
rebocardo
rebocardo is offline
Depends, if doing a gear ratio change with a TTB, do the front first. If both are straight axles, usually the back first. If you have a van or other extremely nose heavy vehicle, do the front first.
Also, depends on where it will see the most use, sand, snow, mud, dirt, woods, etc.
Old 02-04-2009, 07:26 AM
Freaksh0w's Avatar
Freaksh0w
Freaksh0w is offline
I'd say rear for more control. If only one rear tire is spinning, you can't whip the *** end around nearly as easy as if both rear tires are spinning.
Old 02-04-2009, 08:02 AM
teds74ford's Avatar
teds74ford
teds74ford is offline
I have found that one in the rear is pretty good. I don't use 4wd as much as I used to, and when I do use 4wd, it is much more capable. Obviously, 2 lockers would be even better, but if only putting in one, the rear gets my vote.
Old 02-04-2009, 10:26 AM
75F350's Avatar
75F350
75F350 is offline
With that reply, you finally got some advice form experience and not just speculation.
Lets get back to basics and try something that is pretty simple.
IS it easier to push a vehicle or pull a vehicle?
Ever drive a front wheel drive vehicle?
Take two vehicles, one front wheel drive and one rear wheel drive, and try to navigate any incline, or low traction condition.
The front wheel drive vehicle has a much more difficult time with the trek. The rear wheel drive does not get stuck as easilly.
My rigs are all twin stick equiped, and I use front wheel drive quite often. It amazes me, (still) at how poorly the trucks perform in just front wheel drive.
In any conditionm the vehicle struggles when the vehicle is just engaged in front wheel drive. The same trail, or line, or hill, is easier to navigate in rear wheel drive.
Now lets not get into steering dificulties, and weak front axles, this should be a giben, though maybe not, but your best advice is to:
1) Actually determine if a locker is actually suitable for your application
2) Determine whether or not you are willing to accept some of the drawbacks of a locker
3) Verify that your axles are even up to the added loads and stress associated with a locking differential
4) Be confident that your condition requires the use of a locker and that your driving skills are not just lacking. (this is a biggie here. I cant tell you how many rigs I pull out of the mud, or up a hill, or simply have to rescue because the driver thought that after he ran his credit card up to the limit buying all sorts of junk, he was ready for anything. Truth is that the driver should have learned how to "drive". Some driving skills can go a long way.
5) Consider that a locker can and will find a weak link in the drivetrain, so be prepared to make additional upgrades.
6) Traction devices are just that, traction aid. These devices will do very little for a vehicle with weak tires. Consider whether the traction you seek could be obtained by just buying some new shoes.
For optimum traction, and to obtain the best results, installing the locker in the rear would provide the greatest benifits.
Old 02-04-2009, 12:39 PM
brandon_oma#692's Avatar
brandon_oma#692
brandon_oma#692 is offline
WOW i just learned a lot!
Old 02-04-2009, 03:07 PM
Red Ford Truck's Avatar
Red Ford Truck
Red Ford Truck is offline
Me Three.
Thanks for the lesson.
Rick.
Old 02-04-2009, 05:04 PM
Ryan50hrl's Avatar
Ryan50hrl
Ryan50hrl is offline
Although not knowing how you intend to use your truck......anyone who'd driven a rear wheel drive car and a front wheel drive car in snow...knows that you'll get through much easier in the front wheel drive one....
Old 02-04-2009, 05:32 PM
75F350's Avatar
75F350
75F350 is offline
This is simply as the vehicle drives. The front wheel drive vehicle is less likely to spin out, since the rear has to follow, and applying power to the rear does promote the "fishtail", but this is totally different than the vehicles ability or inability to minimize a "stuck".
Back your truck up a hill and see how far it will go before it loses traction.
In fact that would probably have been a better excersize.
Back any two wheel drive vehicle up a hill with low traction and then drive it foward. The truck will do much better going foward.
Most do not have the ability to engage front wheel drive only, so there will be a slight arguement by those who cant, but for those of us that can, the differences are night and day.
Same truck with the same tires and lockers will do better with only the rear engaged than haviing just the front engaged.
The ideal situation is to have both engaged, but the OP had asked about just having one locker, and hands down the best bang for the buck would be to have it in the rear.
Old 02-04-2009, 05:54 PM
78250crewcab4x4
As a fellow twin sticker, I would have to say. First one reason a fwd car usually does well in the snow is because the weight is mostly on the front. second, backing up a hill in rear wd only will not go as far as going forwards in Front wd only, because a trucks weight is biased to the front as well.
So my truck has a LS in the rear, and if I only was going to put one locker in (and IF my front axle could handle it) I would want a selectable locker up front, rather than replacing the LS with a locker. just a thought
Old 02-04-2009, 06:56 PM
BradyCouchman
i would agree with you on that one, with LS in the rear a locker in the front would help more then putting a locker in the rear in place of the LS....
Old 02-04-2009, 10:01 PM
Ryan50hrl's Avatar
Ryan50hrl
It has more to do with the weight distribution than which wheels lead....if you put 800 lbs over your rear axle.....then maybe you'd be equal...
but stock vehicles...about the only one that will go as good as a fwd with a rear wheel drive is the pontiac fiero...where the engine was over the rear....
Quick Reply: Theoretical question about lockers.
