EFI vacuum leaks
on
I've heard of but never seen the use of a smoke generator.. sounds like it would work quite well.
You could also try pressurizing the system with air and listen for leaks, or use a vacuum pump to try to establish a vacuum, it would require something quiet so you could listen for leaks obviously, and you'll have to seal the vacuum attachments at the intake.
