292 Backfires thru carb under throttle
Hello I'm a new member to FTE. I just bought a 64 F250 and it ran like a top till today. While driving it started backfiring thru the carb (2bl) till I let off the throttle. It has a little miss to it at idle, but nothing crazy. I was told that it was a timing issue, stuck valve, vaccum advance, plugs......ect. The vaccume hoses look to be fine, but I think most of the stuff is origional. Has anyone had this problem and what did you do to fix it? I was really hoping to wait awhile to pull the block apart.
Bad spring/s resulting in open valves. Could be any of those and you will only find out by looking into it hands on IMO. Check the timing with a light(dont move it prior) see if it is steady, fluctuating mark is a sign of a worn chain, a vacuum gauge will go miles towards a diagnosis. How to Use and Interpret a Vacuum Gauge
Start looking and get back to us with findings.
In addition to checking the timing, don't overlook the point gap and condenser. I had the same problem with my 292. Last thing I checked was the condenser. That was the source of the problem. Problem repeated in about 2 weeks. Yep, it was the condenser again. Truck has run like new for the past several months.
I agree with bob. Use a vacuum gauge to read the problem. If you know how to use one, you can even isolate it down to what cylinder could be causing the problem or dissy sitting OR... I have the original instruction sheet that came with a vacuum gauge I bought many many years ago. If anyone is interested, I could try to scan the sheet and send it to someone that can post it. I don't do posts well. I do believe it explains the use of a vacuum gauge quit well. Just a thought.
As for the popping, you didn't say if its intermittent or constant. It does sound like a stuck valve or very weak spring - back firing through the valve. If it were a weak spring, I would think it would have been doing all the time unless maybe a broken spring. A compression/leak down test would show something. However, I would start with a vacuum test.
08gasurveyor
41
01-20-2012 09:05 AM
66flareside
46
10-16-2008 03:30 AM
WYO100
13
05-25-2006 08:27 PM
