hey bill / number dummy .....
i was wondering if your books can tell me what i got here . it's a 9 inch out of a 68 pickup 1/2 ton the tag on it what i can read is as follows WDH 4?EC{?} 379{?}50 8 and thats all i can read for now . nearest i can come from a chart i have is 63-67 econoline with a 3:00 gear . correct or what do you have ???? i'd almost say from the looks it was swapped in in place of the oe 9 inch but it fit just like it should . thanx in advance !!
4EC is prolly the build date: 3rd week (C) of May (E) 1964 (4).
No such ratio of 379.
Look at the backside of the tag, it may be easier to read.
Common Econoline E100 1961/74 ratios: 3.00 / 3.25 / 3.50 / 3.89
Common 1960's F100 ratios: 3.25 / 3.50 / 3.89.
thanx bill . i cleaned the tag up , and with some imagination was able to kinda make out what it really was . wdm 28 spline , 63-72 1/2 ton , 3;25 ratio . the tag had the 3 and 5 legible and the m was so messed up it took some patience and cussing but got it !!!!!!!!!! sounds like a good ratio for me and the flatty . might actually be able to go faster than 50-55 for long periods , and it wont sound like the flatty is going to fly apart from being so wound up . thanx again , and thanx to you julie .
Where is the Neutral Switch, on the column or on the transmission? / On the column: 1973/77 / On the transmission: 1978/79
