HELP...best way to dry biodiesel??
Old 01-25-2009, 02:36 PM
PsD007.3's Avatar
PsD007.3
PsD007.3 is offline
right now we use an 80gal aquarium (sp) air pump with dual air lines that hang to bottom of our 55gal drum and let air pump through the fuel for about 24hrs...
Old 01-26-2009, 09:18 AM
Phydeaux88's Avatar
Phydeaux88
Phydeaux88 is offline
If you're going to water wash and bubble dry you need to put airstones on the air lines to break the bubbles up. I also helps to put some sort of dispersion mechanism to spread the bubbles out.
Better yet don't water wash use Magnesol to dry wash then no drying needed. You get a better product and eliminate many problems.
8LITERCOBRA
2009 - 2014 F150
58
09-12-2013 06:58 PM
Dutch123
2009 - 2014 F150
13
10-14-2011 06:55 PM
Str8shooter
6.7L Power Stroke Diesel
16
01-11-2011 08:34 PM
sweet03cobra
1999 to 2016 Super Duty
04-05-2007 07:27 PM
Kevin24
19
01-06-2004 09:29 AM
Quick Reply: HELP...best way to dry biodiesel??
