Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > Flathead V8 and Flathead 6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 01-16-2009, 02:18 PM
galaxie641 galaxie641 is offline
galaxie641 is gaining momentum as a positive member of FTE.
Oil Change time
It is going to be in the 50's this weekend so my '51 Flat 8 is going to get an oil change. I need to know the capacity, no oil filter, and the oil weight. Additives aren't relevant, as I have stocked up on some ZDDP so I just need the proper weight. IIRC they were sticking straight 30 in them back in the day so I assume 10w30 would work but want to make sure.
__________________
'51 F3 Flat8
'64 Galaxie 352 4bbl
'72 F250 400/C6
'92 Grand Marquis
'97 F150 5.4L
'08 Bullitt #3947
  #2 (permalink)
Old 01-17-2009, 10:21 AM
F6Guy F6Guy is offline
F6Guy is starting off with a positive reputation.
I have used rotella 15w40 from day one. mainly because I run that in my daily driver which is also a gas burner and i want to keep the diffrent oils i stock to a minimum. I also run the rotella in my 4020 john dear, model D john deere, and 600 ford tractor. The flathead does not have real high spring pressure so zddp aditives are not that big of a deal as in an overhead valve engine with .400"+ lift. A flathead requires a lot less spring pressure than an OHV. However valvoline race oils still contain good amounts of zddp as they are intinded for off road applications. But any good quality oil will be fine. a dual viscosity oil was not available during the flatheads hey day but is a good choice because it flows better at lower temps than a straight weight oil.
  #3 (permalink)
Old 03-03-2009, 08:22 PM
effie_man's Avatar
effie_man effie_man is offline
Fatty driving the Flatty!
effie_man is gaining momentum as a positive member of FTE.
i use 20w50 as my mains are a little worn so it gives me a little more oil pressure when its all warmed up. i also throw a quart of atf in there to clean everything out and keep the notorious flathead oil scum down to a minimum
__________________
Chris
53 f100 Custom Cab
04 F150 STX 4x4
  #4 (permalink)
Old 03-04-2009, 09:08 AM
petey shoes petey shoes is offline
petey shoes is starting off with a positive reputation.
i also use 20-50 in mine, (59ab), year round. engine is newly rebuilt. 38 lbs at idle-80 lbs when running. put in zddp for breakin, but not needed after that. ps- in 5 degree weather, instant pressure. in case your worried it's too heavy.
__________________
42 1.5 ton marmon herrington all wheel drive
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
