four wheel drive will not engage
12-20-2008, 10:21 AM
on
turn four wheel drive selector switch to 4h or 4l and nothing happens.. no light or anything..worked perfectly before..2005 f150 fx4
12-20-2008, 12:33 PM
take a hammer and lightly hit the electric motor on the back of your t-case
then try 4x4 again.
if it works, only a temp fix. you'll need a new shifter motor eventually
12-21-2008, 09:45 AM
on
thanks alot..that did the trick!!!
12-21-2008, 12:48 PM
keep an eye on it...eventually it will stop doing the trick. then you'll need to replace that little motor
12-21-2008, 01:53 PM
on
mine is not shifting into 4L, it will go in and out of 4H but not into 4L. Any suggestions?
12-21-2008, 05:02 PM
on
You need to have the truck in NEUTRAL to go into 4 low, unlike shifting on the fly into 4 hi. Its something that is easily mistaken and overlooked.
