How many quarts of oil for the 5.0
Old 12-14-2008, 02:39 PM
truknut1972's Avatar
truknut1972
truknut1972 is offline
I have a 92 F-150 with the 5.0. I changed the oil the other day, I put 5 qts. and the dipstick and it still shows that I'm still a qt. low. I looked at the owners manual and it said it takes 5 qts. So how many should I put in it? Thanks, Jeff.
Old 12-14-2008, 03:58 PM
quicklook2's Avatar
quicklook2
quicklook2 is offline
6 with filter.
Old 12-14-2008, 05:32 PM
mstngmikegt's Avatar
mstngmikegt
mstngmikegt is offline
Originally Posted by quicklook2
6 with filter.
What he said. My 95 takes 6 (with filter). Manual for my 95 confirms this....says 5 or 6 (with a filter change). Side thought...who the hell changes oil and doesn't change the filter?!?!?
Old 12-14-2008, 05:55 PM
tseekins's Avatar
tseekins
tseekins is offline
Received 1,221 Likes on 803 Posts
[quote=mstngmikegt;6883697]What he said. My 95 takes 6 (with filter). Manual for my 95 confirms this....says 5 or 6 (with a filter change). Side thought...who the hell changes oil and doesn't change the filter?!?!?[/quote
One can only wonder.......
Tim
Old 12-14-2008, 06:18 PM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
A dumba$$!!!!!!!!!!!!!!!!!!!!!!
Old 12-14-2008, 07:01 PM
05chop's Avatar
05chop
05chop is offline
If the pan holds 5 quarts then you will have to remark the dip stick.This is a stock oil pan correct?
Old 12-15-2008, 07:14 PM
EPNCSU2006's Avatar
EPNCSU2006
EPNCSU2006 is offline
6 with filter.
Right on the money and straight out of the owner's manual. Best I remember, all the gasoline engines from 87-96 require six quarts of oil to refill after an oil and filter change.
Old 12-15-2008, 07:28 PM
justin_brandstein's Avatar
justin_brandstein
justin_brandstein is offline
Acctually alot of mechanics who use only synthetic do it every other... or if the oil change is because of droping a pan or something like that.
Old 12-15-2008, 07:36 PM
EPNCSU2006's Avatar
EPNCSU2006
Seems like with synthetic oil and its extended drain capabilities, the filter would be change more often than the oil, not the other way around...
Old 12-15-2008, 10:28 PM
95F350XL's Avatar
95F350XL
95F350XL is offline
At our shop we change the filter any time we have to dump the oil, its only like a few bucks and you might as well. With syn and the longer oil changes id have to say ud better change it. My boss wants 4k with the semi-syn that we have in a huge tank, and 5K on full-syn and diesel oil changes. I do 3K on what we use in most cars caus thats just me, and ill do like 4 on the syn and diesel just caus thats also me. Id do 3 on the diesel if i could caus that stuff gets so nasty, but with the Fords takin 15 qt, and the chevs/dodge taking 9-12 and at 89.99 we cant do it like that lol.
Old 12-15-2008, 11:44 PM
pfogle's Avatar
pfogle
pfogle is offline
I tend to do 7 to 10k miles on the full syn. I had a girlfriend once who's dad only changed the filter every other oil change. Thought he was saving money. It worked for them her car had well over 250k miles on when it finally died.
Montana Hoss
6.7L Power Stroke Diesel
55
08-19-2023 07:24 AM
mantta
2015 - 2020 F150
03-28-2015 05:08 PM
pickenspolitics
03-09-2015 08:48 PM
grnboger
16
01-07-2014 05:51 PM
Money-Pit
11-17-2013 05:45 PM
Quick Reply: How many quarts of oil for the 5.0
