Suspension lift kit and factory wheels ?
well i was thinking of makeing the jump to a Suspension lift and i hit a problem
well i've been told that i have to use aftermarket wheels for more back spaceing needed for cleanece ..i would like to keep stock fx4 wheels
looked around for pics but haven't found anything otheir then the 20inch wheels on lifted trucks with 6 inch lift
can anyone support this ?
yep, the 17" rim has issues with the lift kits.
the upper and lower control arms are spaced farther apart...and this puts them very close to the inside edge of the rims (front).
the 20" rims have more inner room, so they can still be used. I believe the 17" rims with more offset can be used...but you'll need to find someone with them to ask
