2.3 fairmont
Old 11-24-2008, 08:31 PM
Dragonfox13's Avatar
Dragonfox13
Dragonfox13 is offline
2.3 fairmont
ok, weve got a 2.3 from a 78 fairmont in our skidloader and need to put a timing chain on it, but not sure where the notches on the cam and crank are supposed to be, anyone with some help would be greatly appreciated..
Old 11-24-2008, 08:41 PM
Econoline 150's Avatar
Econoline 150
Econoline 150 is offline
It should be a timing belt. I think theres two notches on the cogged pullyeys, been a long time.
Old 11-25-2008, 07:55 AM
tomw's Avatar
tomw
tomw is offline
Squaremont! There is a pointer on the cam pulley, triangle shaped, and you rotate it to line up with a pointer mounted on the front of the block. The crankshaft key would be at 12:00 for TDC. The distributor pulley - rotate to put the rotor pointing at #1. Loosen the tensioner (two bolts) and push the idler back against spring tension. Thread the belt over all the pulleys, loosen the tensioner bolts and allow the idler to push against the backside of the belt. Rotate 2X in normal direction, put back at TDC, and check for pointer alignment. If they align, tighten down the tensioner and replace all the other parts... Then set the timing to 10btdc.
tom
snailmont5oh
General Automotive Discussion
08-05-2015 01:16 AM
snailmont5oh
15
01-26-2015 08:02 PM
mike L
17
07-13-2006 02:23 PM
R-WEST
New Member Introductions
02-02-2006 06:51 PM
the real Broncoholic
Minnesota Chapter
07-05-2005 10:07 PM
Quick Reply: 2.3 fairmont
