Lets see lowered attitude 2wds dents here
saving up for some STEEL right now, hopefully get some steel, do a little bit of suspension work ( long as s lift bars ), beef up the frame in a few spots it should be stronger, bend out a cage,build a new crossmember in the back to relocate the shocks to be behind the axle housing and at a 90 degree angle, and fill in some holes in the floors and firewall...
on
Most have probably already seen mine before, but I haven't posted in a while so I'll post it again. These are old pics from over a year ago, but it doesn't look much different except a set of body-colored steelies with chrome trim rings. It currently has the motor and tranny out while I complete the 460/C6 buildup and get the Doug Nash auxiliary overdrive installed. Slow progress, but I hope to have it done at some point during the winter (It's snowing here in Pa right now so I wouldn't be driving it anyway.)
DJM 3" beams, 5" rear flip kit.
To keep this on topic...
sounds like you have a busy winter planned. I have a cage build sheet from Chris Alston if that would be any help. We got the mock up fenderwell header finished. It looks pretty good considering I haven't done much tubing work. Would you keep an eye out for a stock grill that is decent. Does not have to be perfect, just better than the LMC junker I have now.
To try to get back on topic,my truck now sits about 5" lower in the rear, and about 4" lower in the front.
I have seen people add rear facing shocks, and keep their original shocks, and it helped quite a bit, so a total of 4 shocks on the rear. Also have seen alot of success using lift bars from the rear end up to about the transmission crossmember. Wheel hop sucks, but if you can work your suspension to transfer a ton of weight, and actually lift the rear of the bed of the truck on a launch, it will help a ton. The more the rear squats on a launch, the more probable wheel hop, and unloading your rear tires is. Ideally you will need to find a way to make the rear of the truck rise a little on launch, alot more weight will be on the tires that way.
#28
#29
