Tranny Trouble
Old 10-19-2008, 06:03 PM
BluByu1986's Avatar
BluByu1986
BluByu1986 is offline
Tranny Trouble
Was driving on the highway yesterday and noticed smoke coming from the truck in the rearview mirror. Pulled over right away and noticed a lot of oil coming from the tranny, mostly from the bellhousing. Had it towed to a Transmission shop to have a look see this week, as I know the guy who owns the shop. We both think that it's coming from the front seal, but won't know till we pull it out and open it up.
Truck only has 102K on it. Anyone else have any problems with their transmissions. Truck is a 2005 F-150 Screw with a 5.4
Old 10-20-2008, 05:50 PM
BluByu1986's Avatar
BluByu1986
Well, I stopped by my buddy's shop tonight after work. He owns a local Tranny shop here in town. Looks like my hunch was right and it was the front seal that had popped out. He had just finished taking the tranny appart when I got there so we could take a look and make sure everything else was in good shape. The front brass bushing was worn in a couple spots, so that's getting changed. There is another smaller gear(can't remember the name) but it goes down inside the planetary gear, it too is showing some wear and is getting changed. The overdrive band has a few burnt marks on it and that's getting changed as well. And since I've got the tranny opened up, I'm getting a shift kit put in since I've got the opportunity.
Should pick up the truck tomorrow after work, if not, Wednesday for sure.
Cheers,
Old 10-21-2008, 05:31 AM
slc10844's Avatar
slc10844
slc10844 is offline
Keep us posted on the shift kit. I'm thinking of putting one in mine but just to firm up the shifts.
Old 10-21-2008, 06:43 PM
BluByu1986's Avatar
BluByu1986
Well, I picked up the truck tonight after work.... He sure does a good job, that's why I keep going back to him.... ie work on my mustang or other vehicles, plus references too of course.
The shift kit is called a superior shift kit. It's meant to help stiffen up the shifts, so it's not so laid back and slow shifting.
So far I like how it feels. But I will keep an update going. I'll check more closer on the bill for another name of the shift kit.
Old 10-21-2008, 09:48 PM
2004 xlt 5.4's Avatar
2004 xlt 5.4
2004 xlt 5.4 is offline
Speaking of the bill what did this set you back ?
Old 10-25-2008, 08:46 AM
BluByu1986's Avatar
BluByu1986
Well, here is the break down of the repair bill. Some parts were changed due to showing some wear and it was decided to change it out now while the transmission was open.
1. Changed the sun shell gear and sun shell. Replaced the sun shell with a heavy duty one which was tig welded not rivited like the factory one.
2. Changed an assortment of seals, bushings, o-rings and gaskets as per usual overhaul.
3. The EPC solenoid was changed out as he found some dirt in it.
4. The Overdrive band was changed out due to some burn marks on it.
5. I also had a Superior shift kit installed while tranny was apart to help with shifts.
6. The Direct clutch discs were changed out also.
All in all, I'm very please with how the tranny works now, shifts are a lot more crisp and not lagged behind. Total cost of the rebuild, including parts and labour was $1,835.74 CDN. I'm always very happy with the work Tom does at his shop, he's done work for me on my mustang and other vehicles before. If anyone is ever looking for a transmission shop in this area, go see Tom at Kingston Transmission, I highly recommend it.
