91 F-150 engine codes.....
Here are the codes i am getting...18-41-53-31-32-33
I understand that 31-32-33 have to do with the EGR valve. I have no vacuum going to the EGR valve. I am going to replace the vacuum switch that feeds vacuum to it.
Code #53 has to do with the Throttle position sensor. I have a volt-meter and will test it and most likely replace it also.
Code#41 is the oxygen sensor with a lean indication. Is it possible i am getting this reading because of the other parts being bad? Or should i replace the oxygen sensor also?
Code #18 is in CM Ignition Diagnostic Monitor circuit failure or spout circuit grounded. This is the one thats putting me over the edge LOL. I am clueless on that one. Thank you for your help......Chuck
I replaced the TPS yesterday. It made a big difference. The engine runs smooth again. I was trying to buy the switch that sends vacuum to the EGR, but i didn't know what it is called so i am going to remove it and take it there to get what i need. The girl behind the parts counter was as helpful as she could be, but could not understand "2-hose 2-wire vacuum switch thing connected to the EGR valve".
Thanks ...... Chuck
Thanks ...... Chuck
merritdc
06-26-2004 08:02 PM
