Bob's F-100 bolt-on IFS
CONSIDERATIONS (When we wrote the Front End Swap Article this was not a choice)
Just some things to consider, along with the other front ifs choices.
The Chevy Nova was classified as a Compact Car, it was a 3200 Lb Vehicle.
The FWD Chevy Nova was last produced in 1979.
The FWD Chevy Nova never had Front Disk Brakes, so what ever they are using is a retrofit.
I assume (maybe we can get Big Bob's to confirm this) that the Nova components they used are from the rear-wheel-drive, disc-brake era (1968-1979).
The only other bolt-on IFS that I have found is from Chassis Engineering. They don't have the hub-to-hub price listed on their website, but if I read their catalog correctly the hub-to-hub price would be $625 for the cross member plus $1350 for the rest of the kit, for a total of $1975 (you'll want to confirm this with CE).
I'm assuming that this includes the rack-and-pinion, although the price sheet doesn't specifically say that.
It's hard to judge just from a photograph, but Bob's-F100 cross member does appear to be more robust than the Mustang II bolt-on from CE (it had better be for $1795 vs. $695 for the MII).
If I read the pricing from Bob's F-100 correctly, the $1800 is for the cross member only.
Thanks for the heads up guys....i understand the table now from bob.
The CE stuff i didnt see a set-up for the 55 only through the 53(ithink it was through 53) is the chassis the same from the 53 to the 55? the template from bobs runs off the referance point of the bump stop. Does the CE run the same template (if not for 55 disregaurd this question) or do you have to find the center point?
You guys continue to give me the best info on the net. its nice to have a place to get vehicle specific info from builders themselves. Thanks again guys!!!
Don't know how their template works. It shouldn't be that hard to mark your center point with a Sharpie before removing your old straight axle (that's what most of the weld-in kits have you do).
If you're like me though, you probably like the comfort of using a template that is based on some existing hole or other reference point.
This is somewhat of a forum mining job, but I have been considering this same thing for my 54. I still haven't found anyone who has used this unit. I read the same Custom Classic Trucks article (online) and got the same email back from Bob's - pictures and hard-to-understand pricelist.
Looks like the bolt in is going to cost about $500 more than the other weld in units from everybody else - considering everything. Well worth it as the bolts should hold up much better than my welds! The straight axle is riveted in - and from what I've seen with my other truck, very substantial rivets. I would like to know what the bolt diameter is and match it up in the rear end. I wonder if the rack and pinion might come non-power.
I would still love to hear from someone who has done this and has at least a season of driving on it. I read an article from years back about bolting an IFS into a 67 - 72 Chevy truck using only 4 grade 8 bolts. I haven't heard of a massive problem with that, but I don't ask chevy guys questions either.
#30
