Offroad & 4x4
How do I know if I have Limited Slip Differential
Old 02-26-2001, 05:26 PM
rcjones's Avatar
rcjones
rcjones is offline
I have a 1993 Ford F150 4 wheel drive. I have the numbers from the rear axle, but I get conflicting answers on whether this is a limited slip differential. The numbers are:
S838B
355 882 L03
Does anyone know whether this is limited slip? Thanks.
Old 02-27-2001, 02:44 PM
Eddie's Avatar
Eddie
Eddie is offline
Two ways:
1. Look on your driver's side door jamb--under "axle" you should have a code like "H9N" which would tell you that the factory stuffed a 3.55 Traction-Loc under there, and/or:
2. Jack up the rear end so both tires are off the ground. Rotate one wheel by hand--if the opposite wheel turns the same amount, you, sir, have a traction aiding device of some sort.
FWIW, if you're interested in Ford's breakaway spec, it is 50 ft./lbs. To check, raise one wheel off the ground, set your torque wrench at 50 ft./lbs., and turn the raised wheel by one of the lug nuts. Ford sez to do this with a special tool which poitions a turning hex directly concentric with the axle center, but...
Eddie
Old 02-27-2001, 09:05 PM
proeliator's Avatar
proeliator
proeliator is offline
[font size="1" color="#FF0000"]LAST EDITED ON 27-Feb-01 AT 10:06 PM (EST)[/font][p]OR, my personal favorite: 1)park your truck on some nice, dry asphalt. 2)Fire up truck. 3)depress clutch and rev motor to @ 7000rpm 4)dump clutch. 5)check for dual skid marks (on the road not in your shorts)
If your knuckles ain't bleeding you did something wrong.
'72 F-250 "Hi-Boy" 4x4, Dana 60/HD44, FE390 @ 400hp(purt near!), 4-speed, custom suspension w 4" lift, mud on black.
Old 02-28-2001, 12:13 AM
85351ho's Avatar
85351ho
85351ho is offline
be careful though, it wont work unless u hold 7,000 for 2 mintues before u dump it to let your tires get ready =)
1985 F-150/351Ho/4wd/6inch with 33's
1979 f-250 429/4spd/5inchwith 36 inch buckshot mudders
on a quiet night your can hear a chevy (lol,you can watch a dodge) rusting away
Old 02-28-2001, 08:37 PM
95xltmud's Avatar
95xltmud
95xltmud is offline
The numbers on your tag mean the following
355 = 3.55 gear ratio
88= Ford 8.8" rear
L= Limited Slip
So your truck is a limited slip(posi - same thing). If the truck was not limited slip (like mine!) there would be a space where the L is on your tag.
-John
Old 03-01-2001, 06:07 PM
mudslinger's Avatar
mudslinger
mudslinger is offline
for a long time i thought i had a limited slip rearend because of that tag on the pumkin. but one day an unwise and unlearned person said to me (take a leak now cause you might wet your pants laughin) that fords suck. i skooled his ##### on that one by doing a brakestand to make his mother cry. but, twards the end only my pass. tire was spinning? what's the deal?
Old 03-02-2001, 01:23 PM
proeliator's Avatar
proeliator
Well, cuz a limited slip is just that, sometimes it won't lock them both up. Thats why God made lockers and spools.
Old 03-02-2001, 06:05 PM
427 cammer's Avatar
427 cammer
427 cammer is offline
hey rc, i must apoligize for some of the bad advice you've received here, i'm refering to what eddie and proeliator posted.
they neglected to tell ya, that you must first lock in to 4wd, then follow their advice..
Old 06-11-2001, 08:46 PM
87ford150's Avatar
87ford150
87ford150 is offline
this wont eat up rubber.go to some place where there is dirt and spin the tires for about 20 feet and see if there are two rutsif there is u have one if not buy a detroit
Old 06-12-2001, 12:16 AM
mudinford's Avatar
mudinford
mudinford is offline
Old 01-05-2008, 07:28 AM
96f150's Avatar
96f150
96f150 is offline
I know this is an old post, but I just bought a 2001 with the 3.55LS, Axle code Is the H9, and the diff take does say LS, But when I make hard left or right turns froma stop, I get the chattering. I had Ford do both rear seals(cause warranty paid) and they did put the modifier in. How long does it take for the modifier to "work" its way in? I looked in the case when they had it open and I didn't see any packs. Are they hard to see? Ford tells me they won't replace them either, because its not a "Safety" issue, sO I was going to do them myself iif need be.
Thanks
Rich
Marioj87
2004 - 2008 F150
01-28-2016 05:19 PM
Platinum08
1999 to 2016 Super Duty
12-10-2014 09:39 AM
BikeMaker
01-28-2010 09:41 AM
TedFromOhio
1997 - 2003 F150
01-08-2010 01:19 PM
bozzzz94
Aerostar
03-07-2007 08:23 AM
Quick Reply: How do I know if I have Limited Slip Differential
