Exhaust Danger... Oh and a lift kit
Well I been eyeing the JEG'S Cat-Back Daul Exhaust, now problem is I can't find but I heard from alot of people/places that you can't use it, on a truck with daul tanks. My truck has Daul Tanks, and well I want daul exhaust, but here is the link to the product.
JEGS 30480 - JEGS Truck (Gasoline) Exhaust Systems - JEGS
I trust all you guys on hear, hell you guys could be locked in a house with my GF and I..... well that I wouldn't trust no man, except the married guys..... then IDK still (I know you married men are faithful) But my point is I trust you guys and only you guys, so umm if I would buy it can I install it on my truck? But the first thing I got to do is repair my old shackles. But I can do that. So guys thanks in advance, I hope it will work, cause then I may get one and put on my truck. Oh one last questions (Yeah annoying me I know) I am thinking about my next real big mod, will be a lift kit. Well what kits do you find works the best? I want a kit that has like everything I need, and I don't wnat to do any of that cutting/welding bull****. Umm height, 4-6 inches, hell 3 inches work too. I want it suspension lift not body lift. But what kits you guys use?
Yeah I know long time no see, missed you all.
JP
JP
As for suspension My Rough Country 6" Suspension lift worked pretty well, the only thing I had to buy out of the box was a pair of radius arm bushings.
Oh and their customer service is awesome! They sent me 4" lift coils on accident and right away they overnighted me a pair of 6" coils an Add a leaf
Hopefully others will add their opinions.
I put that same exhaust on my truck earlier this summer it fits fine although I had trouble geting it to fit, ended up going to the exhaust shop to have them put it on. The pipes do get a little close to the rear axle, but I have air shocks so there is some room,don't know with regular shocks.
I used to want duals real bad too, to the point I actually threw down a lot of coin, only to find it wouldn't work the way I wanted it to.
Anyway, I got lucky. I found a Bassani off-road Y pipe for $175, after I bought my Maremont 3" mandrel-bent tail pipe. I love my set up. Only down side is lack of back pressure, and on my '91 Bronco/5.8 .. it's an 8.75:1 CR. Therefore, I need more back pressure. Here's a pic of the system.
The tail pipe fits like a dream and can be bought for $30 at Autozone. This is the only (with exception of a cat/muffler) exhaust I would recommend.
Hope this helps you a bit!
