Recon Clearance Lights Installed...w/ lots of Pics....56k Warning
In post #5 you say to measure 8.5" from the center line for the 2nd set of lights and then to measure 12.5" from the center for the outside lights. I believe that you meant to measure 12.5" from the line of the 2nd light to the outside light.
That measures 21" from the center line. That's what I see in the picture. BTW: Great pics. Now I know the first mod that I want to do to the new truck. I might drop the headliner before I drill just to make sure that I don't slip and push a drill bit through it.
You really don't need to remove the headliner first, but I understand the caution completely. The only thing that is somewhat close is the plastic bracketry for the in-cab center light. I might have a hole in it that shouldn't be there.
That's why I say to remove it when wiring. This allows you to wire everything up, and then tuck it out of the way.
really hope this helps some guys out with their decision. It was about a 5 hour install. I'm extremely paranoid...so I measured 3-4 times, got ready to drill...and measured again.
I think the headlight mod is next so the heads match the Recon's
excellent write up tylus.... i must say, after seeing yours installed and working, i cannot wait to get mine and do the same. im hoping to have them by mid week and install them next weekend. ill post some pics.....
lets get a new trend going !!
as for those worried about leaks, i have installed 2 previous sets on other trucks.... i used RTV and never had any issues.
Especially after the Lund Visor on this truck and the 3 yrs of chasing down leaks because the previous owner had 1/2 a**ed the install.
so today I went back and put silicone up all over liberally.
and now for some daylight pics
strangly...or not...I've gotten several requests for the exact lights I used.
here ya go.
and
DiscountPowerParts Direct Link to the 2003-2008 Ram Recon Lights
here ya go.
and
