What is the fix for musty defrost smell ?
A musty smell is indicative of mildew...mildew needs moisture. The moisture may be coming from the moisture not getting out of the air conditioner drain (as you probably know the air conditioner runs when the defroster is on). I'd check the drains and make sure they aren't plugged with mud or that a furry animal has moved in (I've seen both cause it)....
Yeah, sounds like a clogged drain. You can get to it by reaching under the fender liner on the passenger side. Not easy but doable. Feel the plastic housing around the condenser, follow the seem to the bottom and there is a very small opening they call a drain. Use a small wire to open, with a little luck it will start draining. If it stays open, it will rid itself of the smell.
When my other truck was at the dealer, they used airsept, some sort of anti mildew spray. Same smell hapened with my 350 and she's been out of warranty for 125,000 miles, so i took the glove box off, and took the 'door' off of where the heater core is and sprayed lysol all over it a couple times. Sealed it back up with rightstuff gasket maker, and haven't had a problem since...well, when it rains I get a wet hay smell, but that is understandable. If you use your a/c turn it to vent a little before you get to where its going to be parked so the evap can dry out, otherwise mildew will come back...
winginit
10-31-2015 04:38 PM
