Flat Head Knock
Old 09-09-2008, 06:44 AM
HOILERAUTO's Avatar
HOILERAUTO
HOILERAUTO is offline
Flat Head Knock
<TABLE width="100%" border=0 itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TD vAlign=top itxtvisited="1">i hear a light knocking noise from my 239 flat head,noise seems to be towards the front of the engine,has good oil pressure.the noise goes awawy when the rpms are brought up a bit i removed one plug wire at a ime to try and pin point noise,but the knock didnt seem to change-i am stumped -i suspected a wrist pin maybe??? any suggestions?
</TD></TR></TBODY></TABLE>
Old 09-09-2008, 07:02 AM
petey shoes's Avatar
petey shoes
petey shoes is offline
got a crab distributor? could be the cam is moving forward. are you sure it,s not a water pump?
Old 09-09-2008, 08:29 AM
HOILERAUTO's Avatar
HOILERAUTO
not a crab type distributor,and water pupms are new
Old 09-10-2008, 07:17 AM
needhelp49's Avatar
needhelp49
needhelp49 is offline
ck your fuel pump rod
Old 09-10-2008, 07:28 AM
HOILERAUTO's Avatar
HOILERAUTO
Took Belts Off -noise Still Thee It Is Defintiley In The Front Area Of The Engine
Old 09-10-2008, 01:01 PM
petey shoes
cam gear-cam thrust-dist gear or bushing-generator bearing/bushing-vacuumn advance
Old 09-12-2008, 06:00 AM
HOILERAUTO's Avatar
HOILERAUTO
<TABLE width="100%" border=0 itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TD vAlign=top itxtvisited="1">i pulled the oil pan down last night to start checking the rod bearings checked #1 and #5 sor far -both look good,will check the rest tonight,how can i tell if i have a bad wrist pin bushing with out taking the pistons out??
Old 09-14-2008, 01:44 AM
Snowking's Avatar
Snowking
Snowking is offline
I guess pull the oil pan disconect the rod and see how much wiggle room, but that's just about as hard as pulling the pistons out.
Old 09-27-2008, 11:02 PM
leonharu's Avatar
leonharu
leonharu is offline
I had the very same problem and it's fixed.Go back to earlier post called Flathead Knock!
Old 10-15-2008, 11:13 AM
55 f350's Avatar
55 f350
55 f350 is offline
well leonhau i wish the search engine on here would find it for me !! i have ? had a knock that i think i have diagnosed and am getting ready to cure , but as a first time flatty owner im always ready to learn ANYTHING !!!!!! i can from anyone and everything .
fordf15091
03-27-2011 07:38 AM
75Ford-Hiboy
1999 to 2016 Super Duty
18
01-18-2011 07:25 PM
gangstakr
10-13-2009 02:31 PM
CBlack350
16
01-05-2009 05:27 PM
NitrousNolan
General Diesel Discussion
08-19-2008 08:45 AM
Quick Reply: Flat Head Knock
