steering wheel removal
i removed mine with out a puller. take off the center horn part with a phillips screwdriver. remove the center nut with a 1/2 drive ratchet and socket not sure on the exact socket size on the nut. once you get the nut off grab the wheel at the 10 and 2 positions 9 or above the center divider) on eithe side of the wheel brace your feet on the floor/firewall(depending on how tall you are) and pull on the wheel alternating pulling hands decently fast. ... (IE.. pull hard with left arm then let off and quickly pull hard with right arm do this 3 - 4 times and it should be in your hands and not on the colum). worked for me no puller necessary
its a 15/16" socket to remove the large nut in the center of the wheel... i do my "ford alignments" (move the steering wheel to center when i replace things like the rag joint and dont get it perfect") i grab the wheel at 12 and 6 and firmly pull on either hand separately until i work it off the splines... on our trucks the wheels arent pressed on as hard as they arent necessary to protect the ignition lock, since ours are on the dash.
hope this helps...
hope this helps...
fullsleeves2
03-28-2008 09:05 PM
