Go Back   Ford Truck Enthusiasts Forums > Misc. > Towing, Trailers And 5th Wheels
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 09-02-2008, 09:07 AM
Scottay's Avatar
Scottay Scottay is offline
Scottay is starting off with a positive reputation.
Dual Trailer Batteries?
I have a 29' 5Th Wheel with a single battery. I am guessing (and will have the battery tested to confirm) that it is probably no longer reliable. I went dry camping this past weekend, for only the second time with this camper in 4 years. We were extremely conservative with power usage and by the beginning of the second night, the battery was drained enough to not even have enough power to light the fridge. Thank god for generators. Can a second battery be added, and if so how is it wired to the trailer and tow vehicle (for charging)?
The original converter was a piece of crap, which I finally had replaced a couple of months ago. The new converter manages the charging of the trailer battery. My guess is the old converter probably over charged the battery numerous times and cooked it.
The current set up obviously charges the battery when the trailer is connected to the tow vehicle with the engine running. Again, how would a second battery be installed?
  #2 (permalink)
Old 09-02-2008, 11:13 AM
grafekie grafekie is offline
grafekie is starting off with a positive reputation.
What's easiest is to replace the original battery with two identical batteries. Wire them together - to - and + to + (to keep the original 12v and just add longevity, the other way doubles voltage. I can't remember which is series and which is parallel... I think what you want to do is parallel.).
You don't want to keep your old battery in the mix without isolating the new battery, and that's way too much effort for what you need.
__________________
Nathan
2002 F150 SuperCab Short Bed FX4 5.4L V8 Firestone Load Level Air Suspension - totalled by Spradley Barr Ford
1995 K3500 Regular cab 8' bed 4x4 6.5L
2007 Featherlite 8413 20x7x7' Stock Trailer
  #3 (permalink)
Old 09-02-2008, 11:39 AM
twayneb twayneb is offline
twayneb is starting off with a positive reputation.
If you want reliable batteries that last longer and give you better power go to two of the golf cart 6 volt batteries. They are more expensive but come out cheaper on a year to year basis. I had my last set for 9 years and they still held a reasonable charge. Also remember to top the cells up with distilled water once or twice a year and if you are in a cold climate pull the batteries and store them using a trickle charge once a month or plug you unit in to AC once a month or every 2 weeks during cold weather.
__________________
Wayne
2000 F-350 CC V-10 4X4 SB
  #4 (permalink)
Old 09-02-2008, 12:42 PM
quaddriver quaddriver is offline
quaddriver has a good reputation on FTE. quaddriver has a good reputation on FTE.
wire them in parallel and in fact, most coaches will have the wiring there. however, from the charger 'in' there is typically a large diode on each charge line to prevent draining back in the event of some failure. (in addition to the reverse blockage from the rectifier)
purists might even put diodes on the battery output to prevent a strong battery from draining into a bad one.
use deep cycle batteries. unless you primitive camp it a lot, you wont drain them down nearly fully which deep cycle batteries like, so they start to sulfate. some of the smart chargers today have a DES phase to alleviate this.
__________________
QuadDriver...
Go Fast, run over sh......stuff
  #5 (permalink)
Old 09-02-2008, 02:47 PM
Scottay's Avatar
With 2 batteries wired in parallel, is the battery charging as efficient as a single battery whether being charged from shore power or the vehicle (i.e.: will it take as long/longer)? I assume that with 2 batteries I will have more capacity for longer stays without the need to "plug-in"? Will the trucks alternator be "overworked" while trying to charge 3 batteries - truck and trailer (it already has a heavy duty alternator as part of the towing package)?
  #6 (permalink)
Old 09-02-2008, 03:47 PM
It should draw the same amount of power, just for a lot longer. The alternator shouldn't work any harder than trying to charge an empty battery. You probably won't see a DOUBLE capacity as far as minutes of light, but you will definately see a huge advantage to having two or more batts.
__________________
Nathan
  #7 (permalink)
Old 09-02-2008, 05:37 PM
kermmydog's Avatar
kermmydog kermmydog is offline
1986 Ford F-250
kermmydog has a great reputation on FTE. kermmydog has a great reputation on FTE. kermmydog has a great reputation on FTE. kermmydog has a great reputation on FTE. kermmydog has a great reputation on FTE.
Smile
Quote:
I run dual 6 volt batteries on my 32' TT. They are far better than dual 12 volts. I had dual 12 volts on the trailer before this one & when I bought this one the dealer recommended I go this route & I'm really glad I did. I have Trojan Batteries. Not that expensive.
  #8 (permalink)
Old 09-02-2008, 10:35 PM
YDM YDM is offline
YDM is starting off with a positive reputation.
Check out this article about replacing an RV 12-volt battery with 6-volt batteries:
Mod #1: 6-Volt Batteries | ModMyRV
  #9 (permalink)
Old 09-05-2008, 09:24 PM
smokestone52 smokestone52 is offline
smokestone52 has a good reputation on FTE. smokestone52 has a good reputation on FTE.
I use the two 6 volt golf cart battery set up wired to produce 12 volts. I am big into boondock camping, and I can go for 6 days with my batteries before I use my generator. I use power very conservativley. Now when it starts getting cold, the batteries only last about 3 to 4 days because the fan for the furnace runs. I have had this set up for three years, and the batteries seem to be real strong. I do have to add distilled water about twice a year.
__________________
'doin what I can, with what I got.
06 F-150 Scab Lariat 5.4 4X4 (Smokestone1)
06 Mustang GT redfire (sally)
And a very powerful Hyundai Accent! LOL
  #10 (permalink)
Old 09-06-2008, 06:57 AM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is online now
˝ empty or ˝ full?
1999 Ford F-550
Kwikkordead has much to be proud of Kwikkordead has much to be proud of Kwikkordead has much to be proud of Kwikkordead has much to be proud of Kwikkordead has much to be proud of Kwikkordead has much to be proud of Kwikkordead has much to be proud of Kwikkordead has much to be proud of Kwikkordead has much to be proud of Kwikkordead has much to be proud of
Another vote for two 6 volt batteries in series.
The six volt batteries are a LOT heavier = more lead plating = last a lot longer.
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, all stock.
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
http://www.gratitudecampaign.org/shortmovie.php
  #11 (permalink)
Old 09-06-2008, 09:52 PM
cangim's Avatar
cangim cangim is offline
cangim is gaining momentum as a positive member of FTE. cangim is gaining momentum as a positive member of FTE.
another vote for 6V batteries in series.
__________________
http://www.ford-trucks.com/user_gall...id=153297&.jpg
Wishin I was still camping somewhere....
-Mike
  #12 (permalink)
Old 09-08-2008, 02:29 AM
bocomojoe bocomojoe is offline
bocomojoe is starting off with a positive reputation.
Another vote for the 6 volt batteries. What ever you do, be sure to get 2 batteries that are the SAME. And when useing 2 batteries if one goes bad you really should replace both. Happy trailes.
__________________
2006 6.0l Lariat 4wd, CC, LWB, Auto, Tow Command, 18 inch wheel option, 10,000 GVWR
  #13 (permalink)
Old 09-08-2008, 06:37 AM
MarkMoore's Avatar
MarkMoore MarkMoore is offline
MarkMoore has a good reputation on FTE. MarkMoore has a good reputation on FTE. MarkMoore has a good reputation on FTE.
That site ROCKS - thanks for the link...
__________________
- The Urban Assault Vehicle -
2001 Excursion Limited, 4x4, V10, 3.73
RoadMaster Active Suspension
2001 Prowler 31G
Equal-i-zer WD Hitch
Prodigy Brake Controller
http://www.ford-trucks.com/user_gall...id=194723&.jpg
  #14 (permalink)
Old 09-09-2008, 09:55 PM
YDM YDM is offline
Quote:
No problem man. That's my site so thanks for the props. Just trying to share the mod love...
  #15 (permalink)
Old 09-10-2008, 05:44 AM
mistakenID mistakenID is offline
mistakenID is gaining momentum as a positive member of FTE.
My vote also for 2, 6 volt deep cycle batteries. You'll be much happier with the result.
__________________
86 F-250 4x4
Cummins BT 5.9
GearVendor O/D
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
