Tow rating 3.55 gears
Ford appears quite confident in the 3.55 gears. For the '09 model year, the only way you can get a F-250/350 SRW 6.4L with 3.73's is by either ordering it with a 6-speed manual and/or 20" wheels. 3.73's are forced with both options. Other than that, 3.55's are your only choice...
When you take overall tire size into consideration, 3.73's with 20's and 3.55's with 18's or 17's endup with nearly the same effective ratio.
I think one would have to tow with it before dissing it. My friend has the 3.55s and we tow over Donner summit all the time (7200' extreme grades). No problemo.
My truck has effectively taller ratio with the bigger tires, I think it comes in at 3.6x ratio, plus the extra weight of the tires to spin, plus I'm down 80 lb ft of torque vs. a 6.4, and I can accerate at will on the steepest grades at that elevation with 19K GCW (a slide-in camper is not exactly aerodynamic at 65mph either).
as an aside I was looking for this info, but maybe someone on the thread can tell me: was the 3.73 also re-rated to what the old 4.10 was before the 6.4? Can you get a 3.73LS with a widetrack front end? (thinking of an '09 order here and dealer says no)
Power stroke, I am a little confused, what does the size of the rim have to do with anything? Isn't it the outside circumference of the tire that is the real factor? If these are the same outside diameter of the tire on the 20's or the 18's it would be the same ratio wouldn't it? And I am just asking because this does not make sense to me.
Thanks for restating, I skipped the last sentence of your post. I wonder why Ford only offers it on the 6 speed or 20" rims when this is the case. Another weird deal that Ford has done. I have 37" tires on my truck so I am just fine with the 3.73 setup. 3.55 would not get me going even slower.
