a few new pics of the swap
well ive gotten started on the swap( 49 f1 to s10 frame) going to be a long road ahead but a fun learning experence
heres a few pics of what i got done last weekend.
[/IMG]
[/IMG]
[/IMG]
ive added a few other pics to my gallery also...
anyway back the the grind. just thought id share a little of whats going on in my world...thanks for the support and keep the projects going
steve-
[/IMG]
[/IMG]
[/IMG]
steve-
Going Slow-
I have an S10 under my daily driver (a 49 Chebby pickup) and I'm happy with it.
For your exhaust consider the Magnaflow 2-in and 2-out muffler or the 1-in/2 out. This solves the problem of the side mounted gas tank. Very nice sound also. Looks like you are channeling it over the frame to get it low. I assume you will raise the floor in the bed? Looking good!
Steve, also in the middle of doing a S10 swap. Are you going to use running boards, if so you better check for road clearance. I started the same way but ended up welding 3" tube on top of the frame rail under the cab to get more clearance, I think I should have about 5-6 under the front of the running board when finished. Now in the process of grafting the original frame rail to the front so I can mount the front bumper.
Brian
Brian
from the looks of it you cut the whole floor out? or was it just rusted and your going to fab up a new floor. The floor of my 49 is in great shape, and i would like to avoid cutting it up as much as possible. Also what wheel base are you using? I have read that the only thing that will really work would be the s10 long bed. And what year frame is that?
kyle
kyle
