E85 - is it better?
Old 08-09-2008, 11:48 AM
4x4fordtrkn's Avatar
4x4fordtrkn
4x4fordtrkn is offline
E85 - is it better?
Does anyone have a gas station that sells E85 in there town and do they use it in there flex-fuel rated F150? We just got one here in Mobile, AL. I have always heard that E85 decreases performance, mpg, and also dirties the engine. My wife went by the station this week and the guy there told her that E85 and/or regular gas with 10% ethanol burns cleaner than regular gas. I was under the impression that this is a false statement.. Can anyone confirm this information. If this is true i would like to start using it since it is $0.30 cheaper.
Old 08-09-2008, 01:01 PM
bridge's Avatar
bridge
bridge is offline
Sick 'n Tired
I get about 9.5 mpg on E85 and it's $.50 cheaper here at my local station. I don't run it regularly b/c the cost/mile is still more than running unleaded with 10% ETOH. As far as the your other questions, it's a matter of debate. It is suppose to lower emissions, although there are well documented claims to the contrary.
Old 08-09-2008, 01:13 PM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
The guy at the station is like the farmers pushing it: they have a financial motivation. Nothing wrong with being financially motivated, but take that into consideration. Its like a vinyl siding guy telling you vinyl siding is the best thing for your home and a brick guy telling you brick is the best for your home. Even the US government acknowledges a big decrease in mileage with it.
Now, saying it decreases emissions is somewhat misleading because while E85 burns 15-20% cleaner than gas it is 25-30% less efficient so it actually increases emissions.
Old 08-09-2008, 04:55 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
E-85 is worthless.
you lose at least 2-3 mpg while running it
you may save a few bucks with an entire tank fillup, but you will lose that money when you fill up more frequently.
Old 08-09-2008, 07:19 PM
bridge's Avatar
bridge
bridge is offline
Sick 'n Tired
Doing some quick calculations it looks like the break even point for E85 is $.80. That is, at a national average of $3.67/gallon of E10, E85 would need to be $2.87 for the cost/mile to be equal.
I had to use my trucks mileage of roughly 12.5 mpg on E10 and 9.5 on E85.
Old 08-09-2008, 07:39 PM
DirtStripHero's Avatar
DirtStripHero
DirtStripHero is offline
Wow. E85 here in Indiana is running around 2.75 or less and has been as low as 2.50 last week. I only get about 1.5 mpg less than gas when using it in my mom's Explorer. I like ethanol personally. I think the explorer runs a little smoother
Old 08-09-2008, 08:01 PM
bridge's Avatar
bridge
bridge is offline
Sick 'n Tired
Yeah, I'd have no problem running it if the numbers added up. It will never be that low in this neck of the woods until they build a switch grass ethanol plant in the southern climes. It's too costly to truck ETOH and it really can't be piped long distances without high pressure or additives.
Old 08-09-2008, 08:31 PM
DirtStripHero
Ya I had heard that it had to be shipped by truck down there. That has to add up. A couple of years ago it was running about the same price as gas, but I think we now have 18 or 20 ethanol plants in state. That makes shipping pretty easy around us. I'd like to see them build some switch grass plants down there and see what people think about it.
Old 08-13-2008, 06:22 PM
BandBFord's Avatar
BandBFord
BandBFord is offline
I found it not worth the money...
I used E85 for a couple of months averaging 9.5 to 10.5 mpg at a cost of $3.25/gal vs $3.85/gal for 87 octane. I discovered that it cost me considerably more to use the E85 than 87 octane even if the 87 was at $4.00/gal.
Here's my quick math...
E85
200 Miles / 10 mpg x $3.25 = $65.00
to go the same distance on 87 octane...
87 Octane
200 Miles / 15 mpg x $4.00 = $53.33 (saving $11.67 every 200 miles)
I check mileage wth each tank full with mixed driving (city/highway) I consistantly get 15.0 mpg on 87 octane and during the 2 months of using E85 (16 tanks) my average was 10 mpg.
Old 08-14-2008, 07:59 AM
Jim Allen's Avatar
Jim Allen
Jim Allen is offline
One point not made is that not just any truck can use E85, only those with Flex Fuel capability (with that nifty FFV badge). Most cars and trucks can use E10, many as much as E15.Old stuff... say pre-'80s... now there's trouble brewing. Even E10 is causing problems with many older cars and trucks. It hasn't been much of a problem until lately, when you have no choice. The ethanol is very hard on old style fuel systems.
I just started researching what would be involved in converting a non-FFV vehicle ('05 F-150) into a dual fuel. Not with one of those aftermarket kits but with either factory parts or something custom built. I'm not all that hot on E85 (even though I am a part-time farmer) but, like it or not, it seems to be coming down the tracks. Might as well use it if the numbers crunch. Around here, NW Ohio, they don't. Yet.
Old 08-14-2008, 10:43 AM
4x4fordtrkn
Did we ever figure out whether it would be cleaner inside the engine to use E86???
Old 08-14-2008, 11:24 AM
ranger88a's Avatar
ranger88a
ranger88a is offline
Alcohol runs much cleaner, however it is more corrosive! It will always be a give and take.
Old 08-14-2008, 06:41 PM
Naturalite's Avatar
Naturalite
Naturalite is offline
Running 10% Eth I loose 2.5 to 3 miles per Gal. I go from 17+ to 14.5. It all costs the same here so I try to stay away from it.
2008 F150 with 4.6l auto 3.55 rear
Old 08-14-2008, 08:07 PM
pepito113's Avatar
pepito113
pepito113 is offline
In south florida e85 is about 20 cents cheaper then regular. And I lost 3 miles per gallon. So it cost me more to run it.
Old 08-14-2008, 08:31 PM
bridge's Avatar
bridge
bridge is offline
Sick 'n Tired
Badge? Mine is a FFV and I have no nifty badge...what gives? What does it look like? Robbed again dag nab it!
Quick Reply: E85 - is it better?
