Jr - if she wants to remove the rug and go back to the HW floors, I'm hiring someone to come in and sand and varnish...I ain't doing it. I'd sand right down to the floor below!
if ya go to home depot -they have a flat sander vibratory type slow but ya can't screw up too bad!just have to use a palm sander for the edges-and a buffer with fibre discs help-after the heavy sanding-as i say i have done it before-it ain't a lot of fun!!
I saw them in Lowe's the other day too.....At least I saw a sander for rent...looked like a huge belt sander....
they should have a flat one-vibrates-pad about ? 12 x18 or so? have used them before-works okay if the floor is not too rough and wood is not too uneven-if it is really uneven ya need the real deal call someone and get the pro job
the pros use one with a drum but it raises and lowers with a lever-still hard on ya if you ain't used to it-and hang on when ya drop the drum-seen a guy go right through a wall with one-his feet slipped and it drug him right into and through the wall-would have been funny but I had to fix the wall ??
