Manual Transmission Recommendation
Old 07-30-2008, 04:00 PM
snj-chemmec's Avatar
snj-chemmec
snj-chemmec is offline
Exclamation Manual Transmission Recommendation
Compatriots:
I have a 1990 F150 with 300 4.9L I6 engine (in wonderful shape) that has a mazda pos 5-speed bolted to it, which is now grinding when I have it in neutral. I would like to toss the mazda and get a nicer transmission, since it leaves much to be admired. Any suggestions? I would like something that gives me good towing capacity without driving my rpm sky-high.
I have heard good about the ZF-5, but am having trouble finding information concerning if the bell-housing bolt pattern is the same for the zf-5s that have been placed on diesel engines vs the 285/300/302 blocks. Any information you have on this would be great. The reason I ask about a diesel-mounted ZF-5 versus that which has been attached to a 300/302 block is that I have found a zf-5 which was on a diesel for $750.
Let me know what you think and what you know. I appreciate your help.
Old 07-30-2008, 07:01 PM
EPNCSU2006's Avatar
EPNCSU2006
EPNCSU2006 is offline
There are about three different configurations of the ZF. You will need a small block version for the 300 as the diesel and big block versions won't match. You didn't mention if it were two or four wheel drive truck (have to have a matching ZF), but with the two wheel drive trucks, you'll need a new driveshaft for the ZF. I think the length difference is less on four wheel drive trucks and you may be able to use the same one, but I do not know. My experience is with the two wheel drive version. Maybe this link will help: http://www.zf.com/na/content/media/i...ion_Charts.pdf
from this main site: ZF Friedrichshafen AG / Pickup Driveline
Old 07-31-2008, 06:37 AM
snj-chemmec
It is 2wd...
Old 08-01-2008, 09:14 PM
mstromni's Avatar
mstromni
mstromni is offline
On a 4wd, you need 2 new driveshafts, not just 1... the difference is 3.5" longer rear shaft and 3.5" shorter front shaft. Not sure on the 2wd.
I would not buy the ZF unless you like winding your engine up a lot - the gears are widely spaced. Or, youcould get a diesel ZF and a gas Zf and swap the gears - diesel ZF's were made for lower revving motors.
Realize that the ZF is really a 4 speed, with a granny gear useless for normal driving. However, it has overdrive, so for "normal, around town driving, you have 3 gears to work with. I don't mind it with a 302 and 3.55 gears, but it might not work so well with a 300.
Old 08-02-2008, 09:55 AM
84-250's Avatar
84-250
84-250 is offline
First off, welcome to FTE
second, look down in my post and view my classified ad, I have a 2wd ZF. Are you are close to ohio?
Old 08-02-2008, 01:44 PM
EPNCSU2006's Avatar
EPNCSU2006
The 300 six should do just fine with the small block ZF and the stock gear ratios. Ford put the ZF behind the 300 from the factory, so I would think it works fine as-is. It can't be any worse than the transmission in my truck (no granny, geared like a five speed without third).
