Wheel Question
Like you I also have an F350, except mine is an XL and came with 17 inch wheels. I now have 18 inch Ford rims I bought on Ebay. I don't believe there is any difference in our running gear so if your using Ford rims I would say it would work just fine. Do remember smaller wheels will usually mean less payload if your hauling anything. If your going to smaller wheels to lower your truck you will not gain very much.
that does not make sense. an 18" tire would measure 18" and a 20" tire would measure 20". What tire are you comparing on these rim sizes? Are they the same tire? I know that my 18" rim with 37" tires measured the exact same height as the 20" rim with the same manufactured 37" tire.
And Caprang, just yanking your chain a little.. L
Many vehicles will accept smaller wheels than OE, as long as the back of the wheel is designed to clear the calipers. We regurally test and list smaller wheels for snow use.
You can see here:
Snow Tires - Find the best Winter Tires at Tire Rack
Anything we list is tested and guaranteed to fit. Call me if I can assist...
You can see here:
