Go Back   Ford Truck Enthusiasts Forums > Diesel > 4.4L Ford Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
4.4L Ford Diesel Discuss the much rumored 4.4L Ford diesel engine
Is F-150 Still King?
  #31 (permalink)
Old 04-28-2009, 10:15 AM
American Thunder's Avatar
American Thunder American Thunder is online now
1978 Ford Bronco
My Garage
American Thunder is starting off with a positive reputation.
I would think a diesel should get 50%-100% better fuel mileage over the gas engine, not just 20%. It must be loaded to death with emissions.
  #32 (permalink)
Old 04-28-2009, 02:54 PM
wiscvanman wiscvanman is offline
wiscvanman is starting off with a positive reputation.
that is a 6 cyl engine towing around aro 6000 lbs of brick. i think that mileage is pretty decent. yes it will be strangled by emissions just like the current engine. guys i know get 20-22 in their 7.3 cargo vans regulary. best mileage for my 4.6 was 18 occasionally and more like 15. not much of a difference.
my tdi jetta gets 35 city and 40-42 hwy. the like gasser would get 22 city 27 hwy. in a smaller package the percent you expect is available.
Side-by-Side Comparison
unfortunately heavier trucks and diesels ae not tested. wish they did.
  #33 (permalink)
Old 04-29-2009, 10:20 PM
1978 Ford Bronco
My Garage
Well, heavier diesel trucks have deeper gearing for pulling huge loads, they're not purpose built for fuel mileage, they're built for PULLING like a locomotive. Also, they need to drop this V6 idea and get with the inline 6.
  #34 (permalink)
Old 04-29-2009, 10:47 PM
Lead Head Lead Head is offline
Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE.
There is no reason for an inline 6 in an F-150. Longer, heavier, and tall. An I6 will not make any more torque then a V6 with the same bore and stroke.
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
  #35 (permalink)
Old 05-01-2009, 09:01 PM
1978 Ford Bronco
My Garage
I wonder how wide and tall a V6 with a 4.72" stroke will be.. huh
  #36 (permalink)
Old 05-01-2009, 09:40 PM
Stillen GLE Stillen GLE is offline
Stillen GLE is starting off with a positive reputation.
will this be in the expeditions as well? I am assuming
  #37 (permalink)
Old 05-01-2009, 11:21 PM
Quote:
What kind of engine do you have in mind that would have a 4.72" Stroke, Cummins 5.9?...You realize that that would be a ridiculously huge engine for a half ton? If you want to play that game, the Ford Cologne 4.0 V6 has a 3.32" stroke, another 1.5" of deck height on either side to bring it up to 4.8" stroke isn't going to make it that much bigger at all - and it still be a hell of a lot more compact then a Cummins 5.9.
So I still do not see what your point is.
__________________
- Ian
  #38 (permalink)
Old 05-03-2009, 09:10 AM
1978 Ford Bronco
My Garage
I think a diesel such as a 5.9 is perfect for a 1/2 ton. I'm putting one in my Bronco, in fact. A diesel with 440 ft/lbs of torque @ 1600 rpm is great for power and for fuel mileage. Some say it's too much for the stock axles, but they swap 4bbl 460s in 1/2 tons/Broncos all the time, and they make similar torque and twice the horsepower of the diesel.But that's all personal preference, no arguments there. I like a lot of motor.Well, since you only need half the total stroke at each end of the piston travel, you would actually only need an additional .7" of deck height for a 1.4" stroke increase. The 4.0 has only a 3.32" stroke, and a rod length of 5.748" Do you think you can just add deck height to clear the extra stroke? Sure you'd have the room at the top, but what about in the crankcase? All that extra counter weight size and rod caps and bolts have to swing around in there, so the entire case will need to be enlarged by a LOT to clear it all. (3/4" all around??)This means the block is now wider, bigger, and heavier.Then you have the issue of rod to stroke ratio, which in this stroked 4.0L V6 is now down to 1.2:1.(4.72" divided by 5.748") Piston life expectancy will be measured in terms of days or weeks, not years.The rod in the 5.9L is 7.55" long, giving it a rod to stroke ratio of 1.6:1. So you would need another 1.8" of rod length in this 4.0L V6, making the deck height a total of 1.8" + .7" taller. Now account for the required piston height for the increase in wrist pin diameter to withstand the diesel service, add another .25". (1.8" + .7" +.25" is slightly more than 2 and a half inches more deck height. (I won't even count the fact that the diesel pistons are taller) The stock deck of the 4.0L is 8.858", so now it's going to be 11.38" inches.You think this stroked V6 is still compact??? A 460 only has a 10.3" deck.And to top this off, now we have a V6 design with its inherent poor reciprocating balance to deal with, instead of the inline design's near perfect balance. (And it's quite a bit wider and taller than a 460.)Modern engineers love to make things "compact" so everything fits so nice in the engine bay. A big 1/2 ton truck, and the engine bay is smaller than my Mustang's and you have to make do with a V6, and it's a nightmare to work on. Thank God I'm not repairing cars and trucks for a living anymore.You're probably right, there likely isn't sufficient room for an inline 6 in the new trucks, but that's the fault of the manufacturer. I won't be buying anything with a V6 engine. (gas or diesel)
Ford should design a good solid inline 6 diesel of their own, that's at least as good as the Cummins, if not better,(I know Ford could do it) and use this SAME engine in ALL their full size trucks.
__________________
* 1983 Bronco -"Old Blue". Rebuilt '95 300 converted to carb, '95 5-speed, 9" rear, 3.55 gears, 22 mpg.
* 1978 Bronco - "BB78". 12V Cummins power, C6 auto, NP205, 9" lift, 35" BFG tires, 3.50 gears, trac-locs.
  #39 (permalink)
Old 05-03-2009, 11:51 AM
You are also forgetting V6s have a 60* V (atleast non-hacked properly designed ones). So even if the deck height was that high, it would STILL be narrow then a 460, shorter then an I6, and not as long as either one of them. The 5.4 Modular engine is just as wide - if not a bit more then a 460. So the narrower theoretical 5.9 V6 would have no problem fitting in. Modern 60* V6s with split crank pins/flying arms are plenty smooth, even 90* V6s are now acceptably smooth. What this all matter anyways? We are talking about a 4.4L engine, not a 5.9L. There is really no point to a straight 6 anymore, unless you are a smoothness freak (in which case you should just get a V12), or you like looking at tall, straight engines.
As far using the same diesel engine in all their trucks - not even Dodge is doing that. They are going to be sticking a 5.6L V8 Cummins in the 1500s, and potentially a smaller V6 Cummins in the Dakotas.
__________________
- Ian
  #40 (permalink)
Old 05-03-2009, 02:10 PM
1978 Ford Bronco
My Garage
I think 4.4L is too small for a 1/2 ton truck,(I wouldnt use it in a smaller truck like a Ranger either, I'd use something like the Cummins 4BT ) and judging by the low predicted fuel mileage of these new diesels, I'd say it's not a good direction to go. 20% more mpg over the gas models just doesnt offset the higher cost of the fuel.And I don't like dodge trucks, I would never buy one. I don't really like the newer Cummins, either, due to all the electronic crap and emission controls that hang on them. Incredibly powerful and durable, yes, but a nightmare to work on. Older generation all-mechanical 5.9 Cummins, on the other hand, are one of my favorite motors, with good reason. (ease of maintenance is one of the big factors. I HATE working in tight engine compartments, so the narrow inline is a beautiful thing)You present interesting points, but going by my own experience, a V6 diesel will never be as good as an inline 6 diesel. On that, we'll just agree to disagree.
__________________
  #41 (permalink)
Old 05-03-2009, 04:12 PM
As far as power, you have to consider that todays diesels can wring A LOT of power out of not to many cubes. I've heard of anywhere between 250-300hp and 400-450 ft-lbs for the 4.4. That should be enough to haul around an F-150.
Unfortunately the electronic crap is something we all have to live with now, but on a plus side, it has had years to develop and mature, starting with the first electronically fuel injected gas engines
__________________
- Ian
  #42 (permalink)
Old 05-10-2009, 09:21 AM
worm5932 worm5932 is offline
worm5932 is starting off with a positive reputation.
i think a half ton diesel sounds like a great idea! and that kind of estimated power will be more than enough, also banks will be fast on increasing power outputs. i know i cant leave anything stock so i would definitely consider adding one to my garage.
  #43 (permalink)
Old 05-21-2009, 10:44 PM
h2guy h2guy is offline
h2guy is starting off with a positive reputation.
The copywriter for the mag sure isn't much of a truck person, to wit::::
To be built in Mexico, the 4.4-liter V-8 will be offered in production F-150s by late 2009, and by 2011 it is expected to be the base diesel engine in Ford's Super Duty pickups.
According to this "person", we ain't gonna be pulling 15k lb trailers with a 4.4 in a Super Duty.
__________________
'01 7.3 SC 6x6 Lariat "Hercules"
Undocumented Alien?? So a drug dealer is an Undocumented Pharmacist, huh?
  #44 (permalink)
Old 05-23-2009, 01:14 AM
rambuck's Avatar
rambuck rambuck is offline
rambuck is starting off with a positive reputation.
Quote:
Originally Posted by powerstroke1350 View Post
im not buyin it. the new engines wont be called powerstrokes
The new 6.7L is called powerstoke and it is all ford design and build.
Tags
2000 , f150 , ford , v6 , wisc
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
