Weight of my '89 7.3 whole truck
If you have two wheel drive, I will guess two of those cheaper plates will almost work, your empty weight is going to be about 6600 pounds.
If it is a 4x4, you will be about 7300 pounds.
If you haul anything, you better stick with 8800 pound plates.
The registered weight must exceed the truck, the passengers, anything in the truck and anything towed behind the truck.
That is why I have 20,000 pounds as my registered weight.
3,000 lbs!!!! Wow, I think thats what a vw jetta or A toyota prius weigh. My heavy duty half ton chevy weighs about 5500-6000 and thats with a small block gass.(tool box, thick sprayed rhino liner, bumber.) A loaded 7.3 engine with exhaust mans is already nearly 1000 lbs. Then the tranny and torque converter and probably a fairly heavy rear end so now were probably close to 2000 just for the drive train. I don't know how much that front susspension weighs along with the chassis, cab and bed. You better start choppin parts off cause you got alot of weight to drop. My ford 2wd auto (a little bigger cab) dry weighs right at 8000 lbs.
No Offence on any of this, Its just....you might want to set $75 back. I don't blame ya though, Any way to save some money. Probably even get better fuel milage at 3000 lbs. Well, have a good day.
Received 3,108 Likes
on
