1997 aerostar, #1 fuse blowing
Fuse F1 protects the brake lamp circuit. Is it blowing when the brakes are applied to make the shift (that's when the interlock is actually activated) or when the shifter moves out of PARK into REVERSE?
Try starting in N and see when it blows.
Quite honestly, I just don't see it being the interlock itself, I'd suspect its a short on the brake lamp circuit which is quite extensive on this vehicle.
Steve
Steve
