Wheel hub caps keep falling off!
Old 07-06-2008, 11:38 AM
2K3 Mach's Avatar
2K3 Mach
2K3 Mach is offline
This is the strangest thing... I have a 98 4x4 off road with the 16" chrome steel wheels.
I get new tires at 183,000, and since then I've had 4 wheel covers fall off of 3 different wheels! What the heck?!?!
I've rotated tires the entire time, but why now are they falling off???
It's not like I see Rangers and Explorers on the road with missing hub caps, so it's not happenning to a lot of people.
Anyone experience this? The only thing I can think is that the steel wheel behind the chrome cover is rusting and it's making the cap pop off?!?!
Thanks.
Old 07-06-2008, 09:24 PM
reddog99's Avatar
reddog99
reddog99 is offline
If you haul butt around corners, it can make a wheel flex enough to make flimsy caps fall off, but maybe they weren't installed correctly?
Old 07-06-2008, 09:30 PM
BlackNGoldRules's Avatar
BlackNGoldRules
BlackNGoldRules is offline
Thanks.
It's happened with 2 of my hubcaps and I was never able to find them. I have those small center hubcaps that are just big enough to cover the lugnuts. I went on ebay and picked up a couple more for pretty cheap. I'll see how long these ones last before I hit another bump or something.
Old 07-07-2008, 06:47 PM
Rangerman Stan's Avatar
Rangerman Stan
Rangerman Stan is offline
If the metal clips on the inside of the hupcap are bent wrong or missing then they won't hold on to the wheel or lug nut tight enough and will come off easy. Some of them only have three sets of clips to fit over the lugnuts, so they all need to be there. If the cap clips hold on to the lugnuts, make sure the tire store didn't change some of the lugnuts to regular ones. The stock lugnuts have a flange for the hub cap to grip when it's put on. Regular lugnuts don't have the flange.
powerstroke1869
21
03-12-2020 10:57 AM
ruschejj
6.7L Power Stroke Diesel
27
10-27-2014 07:56 AM
xmontex4
1999 to 2016 Super Duty
10-31-2013 01:04 PM
green53
02-19-2011 07:49 PM
Tomget
13
10-19-2010 10:57 PM
Quick Reply: Wheel hub caps keep falling off!
