View Poll Results: Alternative Diesel Fuel Usage
I make and use Biodiesel
19.00%
I would like to make biodiesel
45.67%
I use straight veggie oil
14.00%
I use Waste motor oil
7.33%
I use a blend
12.00%
I purchase retail biodiesel
25.00%
Multiple Choice Poll. Voters: 300. You may not vote on this poll
Biodiesel Roll Call
Old 12-14-2014, 11:59 PM
TheCurtster's Avatar
TheCurtster
TheCurtster is offline
Thanks for all the advice. I plan on visiting some local restaurants in the morning. I'm thinking that if I can get as little as 20 gallons a week I'll be set.
Curt
  #137
Old 12-15-2014, 09:09 AM
Rushmore X's Avatar
Rushmore X
Rushmore X is offline
Keep us updated on you progress & good luck.
  #138
Old 12-18-2014, 01:58 PM
monsterbaby's Avatar
monsterbaby
monsterbaby is offline
just an aside for methanol.
I get mine from one of 2 places. The local fuel supplier for propane etc has barrels, last one cost me $214 including tax, but I found another guy that builds race car chassis and he also sells bulk race gas including methanol. You need your own barrel but he is almost always cheaper, this year was $3.10/gal
I just did a fast search in yellow pages using your location listed and it came back with several suppliers of race gas.
Racing Fuel in Thousand Oaks, California with Reviews & Ratings - YP.com
  #139
Old 12-21-2014, 09:56 PM
TheCurtster
Progress
So I brought home my processor yesterday...
Got the whole mess, processor, methanol drum, bunch of KOH, filtering stuff, transfer pump setup
I gave $700 for everything. Now doing a bunch of cleaning up of stuff, as the system hasn't been run in about 18 months.
After I got home, we went out for dinner, and before we left I asked the owner about his used oil. Went home with about 25 gallons of oil, and his promise to save more for me. So far so good!
Curt
  #140
Old 12-21-2014, 11:01 PM
binuya's Avatar
binuya
binuya is offline
How are you planning to wash?
  #141
Old 12-22-2014, 11:39 AM
TheCurtster
The processor has a spray ring thing in the top that hooks to a garden type hose. Idea is to finish the batch, pull off the glycerin, and then spray. Drain off the water, and then off to a bubbler drying tank.
Sound reasonable?
Curt
  #142
Old 12-22-2014, 01:48 PM
Rushmore X's Avatar
Rushmore X
Fabman and others here convinced me to dry wash. Their argument was that you want to remove water from the biodiesel, so why would you go and add water back into it. Made sense to me...
I did try water wash once, formed an emulsion. Had to de-water and reprocess the whole batch. What a PITA...
  #143
Old 12-22-2014, 11:33 PM
binuya's Avatar
binuya
binuya is offline
Sound reasonable?
Curt
Sounds like it should be fine. I water wash and have a separate wash tank. Then I return it to my cleaned processor for heated spray drying. Water washing is more time consuming, but I am confident that my finished fuel is of great quality. One of these days I'll re-configure my set up to do dry washing, but for now, I have a great system and have become quite adept at handling the periodic trouble batch, i.e. excess soap/emulsion. And believe me, you'll run into it on occasion. All it takes is patience and time. Just make sure you do the the tests for conversion, soaps, and moisture, and you'll be good to go.
  #144
Old 01-09-2015, 10:47 AM
TheCurtster
The competition
So I'm out hitting the local restaurants up for their used oil, when I run across THIS:
They are paying the restaurant owner $.70 a gallon for their oil, according to one manager I spoke with.
I forge on, and got another owner to let me give him a jug and funnel... Says maybe 5 gallons a week. Couple more of those.....
Curt
  #145
Old 01-09-2015, 01:30 PM
binuya's Avatar
binuya
binuya is offline
I would be surprised they would actually pay that much today, especially since the biodiesel tax credit has been phased out. With the recent drop in fuel prices, it's going to be even more difficult for commercial biodiesel producers to make money. And speaking of lower fuel prices, it's also usually the time when many home brewers slow down or drop out of making biodiesel. This is when I ramp up production and can usually find cheap and/or free materials, equipment, and chemicals. I recently bought a couple drums of methanol from a guy quitting biodiesel production for pennies on the dollar. I'm stocking up because fuel prices will go back up again eventually.
Another source for WVO, if you haven't already checked it out, is your local craigslist. Enter 'fryer oil', 'cooking oil', 'vegetable oil', or 'wvo' in the search box. Lately, I've been finding more oil around here almost every week. Good luck!
  #146
Old 01-26-2015, 01:51 PM
TheCurtster
Progress and question
My processor has been completely cleaned and refurbished. I've done pretty well with CL ads and have probably accumulated 150 gallons of oil. I cut the top off a 55 gallon plastic barrel and strained my oil thru 400 then 100 micron barrel strainers. This is my settling tank. This oil looks good and titrates at 3.5.
Recent score:
For fun I took about a half liter of the oil and tried a micro batch in a mason jar. Using NaOH, I made this:
Any idea what the cloudy stuff on the bottom is? I haven't washed this ... Is that the problem? I want to get this right before I make 40 gallons of crap.
Thanks!
Curt
  #147
Old 01-26-2015, 02:21 PM
binuya's Avatar
binuya
binuya is offline
Hard to tell. Likely to be soaps, but it looks like it's moving around in your jar so it's a bit hard to tell. Depending upon temperature, it could also be high melt point esters. I say give it a few washes, dry it, and see what you've got. You've definitely got the right idea doing small batches first. I did about a half dozen or so mini batches before I did my first big batch. It helps a lot to watch how the various stages react and look. Keep posting progress and good luck!
  #148
Old 01-26-2015, 03:56 PM
binuya's Avatar
binuya
binuya is offline
By the way, did you do a 3/27 test for conversion?
  #149
Old 01-26-2015, 07:10 PM
TheCurtster
Yes, I did the test... Came out perfect.
Curt
  #150
Old 01-27-2015, 08:58 PM
TheCurtster
Sprayed my micro batch with some warm water...
Took care of the weird cloudiness. We'll see what it looks like in the morning.
Curt
Quick Reply: Biodiesel Roll Call
