Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 6.2L Boss
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
6.2L Boss Discuss the upcoming 6.2L V8
Is F-150 Still King?
  #16 (permalink)
Old 07-09-2008, 02:23 AM
Lead Head Lead Head is offline
Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE.
Quote:
Originally Posted by dkf View Post
Turbos don't produce power from heat. They produce power from moving air/gases from the exhaust. Heat is the enemy of making power with any forced induction. Thats why intercoolers and water/meth injection can up the power significantly by reducing temps. All the turbo problems Ford has had in diesels makes me very warry of the turbos in the ecoboost. I guess we'll see how it turns out.
Those moving gases are the result of expansion from the heat of combustion. So yes, turbos in a sense do work on heat. Heat on the turbine side has little do with heat on the compressor side. Compressor side heat is caused by the compression of the air charge.
The 6.0 turbo problems were the result of diesel soot causing the variable vanes of the turbo to respond slow or completely stop moving. Gassers don't really have a problem with soot. Not to mention ford doesn't even make turbos.
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
  #17 (permalink)
Old 07-09-2008, 11:16 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future
Uh, not to get further into a useless debate, but ... the "expanding exhaust gases" actually hit the cooler exhaust piping and CONTRACT. The engine is pumping the already expanded gases out the exhaust port - the "expanding gases" gives the engine it's power by pushing on the pistons.
But anyway ...
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #18 (permalink)
Old 07-24-2008, 05:39 AM
wendell borror wendell borror is offline
wendell borror has a great reputation on FTE. wendell borror has a great reputation on FTE. wendell borror has a great reputation on FTE. wendell borror has a great reputation on FTE.
The boss engine will be used, ford has too much money invested in it. They just like playing head games with the competion and us. My dad is a ford retiree, and he gets a magazine every month called ford world. According to ford world, the boss engine is still on track, however, release dates keep changing. High gas prices or not, there's still people out there that need and will buy trucks. In the same token, the competion still has ford out muscled in truck engines. To get people to buy your truck instead of someone else's, you need an edge, the boss would be that edge. It's not like the boss would be the only engine choice, but it should be an option for those who need brute power in thier trucks. I'm sure they will sell a lot of them, cause people buying trucks need them for one reason or another and it isn't to save gas.
__________________
2009 FORD RANGER fx4 off/road, 5-speed manual, torson diff and rancho's!
2008 mercury mariner 4x4 V-6, automatic.
1987 jeep wrangler, 258, 5-speed
  #19 (permalink)
Old 07-24-2008, 08:41 PM
97squarebody 97squarebody is offline
97squarebody is starting off with a positive reputation.
Quote:
Come on now, you are actually applying logic to the situation? I thought we were supposed to be running around like chicken little screaming "the sky is falling". After all that is what many of the more vocal people here are doing.....
__________________
CL
So, who hired Wile E. Coyote as a consultant?
1997 F-250 4WD W/460 & a manual
2008 Explorer Sport trac
2003 SVT Focus (The Go-Cart)
1967 Mustang Coupe W/351W & a 3spd. (Temporarily Retired)
  #20 (permalink)
Old 08-11-2008, 01:36 PM
phelios27's Avatar
phelios27 phelios27 is offline
phelios27 is starting off with a positive reputation.
The 7.3 powerstroke was and still is very reliable. I think turbos are the way to go as well. Some nice Turbonetics T4's or even just one big 60 trim would probably do the trick...the only catch would be making sure the power is useful down low and throughout the power band...quad turbos perhaps?
__________________
1997 Ford F-250 HD 7.5L 460 Long bed. Dana rear w/4:10 gears. 4X2 automatic. All stock w only 97k.
1991 Mx6 GT turbo. 3" turbo back w/magnaflow cat/muffler. NGK plugs/wires/Kia fuel filterPRD MBC @ 14psi. 190whp and 261ftlbs torque
  #21 (permalink)
Old 08-11-2008, 03:11 PM
tjthegreat tjthegreat is offline
tjthegreat is starting off with a positive reputation.
Quote:
the 7.3 was a good engine imo much more reliable than any other diesel ford has built
__________________
92 F-150 300I6/M5OD/3.08/64k
77 F-150 302/V8/3.55/224k
88 Chevy2500/350/4.11/179k
98 F-150 4.6/3.55/112k(sold)
  #22 (permalink)
Old 08-11-2008, 05:42 PM
Krewat's Avatar
I believe the EcoBoost thing requires a variable-vane turbo - which haven't turned out to be so reliable.
__________________
  #23 (permalink)
Old 08-11-2008, 07:32 PM
Quote:
Ford didn't built the 7.3, or any of the powerstroke family.
The main problem is that most of us have only seen the VGT turbos on the 6.0, which get sooted up.
Gas engines have far less carbon/soot output. Most gas engines I've seen with VGT turbos are just fine
__________________
- Ian
  #24 (permalink)
Old 08-11-2008, 10:46 PM
i kno none of the big 3 make their own diesels,i was reffering to the truck,but mis worded it
__________________
  #25 (permalink)
Old 08-13-2008, 12:58 PM
DanielC DanielC is offline
DanielC is starting off with a positive reputation.
Turbos do use heat
The exhaust side of a turbo does use the heat in the exhaust. The turbine wheel controls the expansion of the hot gases moving through it, and the net loss of heat in the exhaust gasses is converted to rotational enegry. That rotational energy is used to spin the compressor wheel, and that increases the pressure on the intake side of the engine. Part of that enegry also heats the intake charge. You cannot compress a gas without creating more heat in that gas you just compressed.
The economy gain comes from waste heat enegry in the exhaust is being used to do some of the compression of the intake air, and the piston does not have to do as much work to compress the air before the power stroke.
About a third of the total chemical energy in the gas you burn is comverted to mechanical motion. About a third is converted to heat, the cooling system has to get rid of, and about a third just goes out the exhaust pipe.
  #26 (permalink)
Old 08-13-2008, 01:30 PM
Krewat's Avatar
Quote:
If the turbine wheel is using energy to create work, the exhaust gas BEFORE the turbine is going to compress. There is no reason for the exhaust gases to expand AFTER they are burned, there is no extra heat being put into the exhaust gases. Heat is being LOST.
It's really just the backpressure pushing the turbo. Which also means, a small amount of energy is lost from the engine in pushing the turbo.
Turbos are NOT free power.
__________________
  #27 (permalink)
Old 08-13-2008, 04:01 PM
If a turbine does not use the heat, and works on backpressure only, can you explain how every gas turbine and jet engine in the world works?
  #28 (permalink)
Old 08-13-2008, 04:37 PM
Krewat's Avatar
Uh, much different use of the word "turbine" ?
Jet engines take incoming air, mix it with fuel and burn it. The energy applied to the output turbine makes the intake turbine compress air, for a better burn, which in turn drives the output turbine, adding energy to the intake turbine. The resulting gases go out the back making thrust. Some applications, take a jet-powered helicopter as an example, use a transmission to take rotational energy from the turbines and drive the rotor. The higher the pitch of the rotor (more resistance), the HIGHER the pressure inside the jet engine. In other words, impede the turbine, pressure increases in the combustion chamber.
A turbo charger is more like a steam turbine, except the rotational energy is then used to compress air into the engine intake. The higher the compression on the intake side, the higher the pressure on the exhaust side before the turbine.
Which is backpressure.
I'm not explaining it correctly, most likely, I'm doing three things at once
__________________
  #29 (permalink)
Old 08-13-2008, 05:40 PM
Just so we understand each other. The turbine side of a turbocharger is the exhaust side, to be more specific, it is a "radial inflow gas turbine". Most modern jet engines, and gas turbines use an axial flow gas turbine. The compressor side of the turbo is the intake side. It is just a centrifugal compressor.
If you increase the pressure on a gas, either the temperature goes up, or the volume goes up. Sometimes both.
If you increase the temperarture of a gas the pressure goes up, or the volume increases.
If you decrease the volume of a gas, the pressure goes up or temperature goes up.
If you allow a gas to expand, the temperature drops, and the pressure drops. This is why your air tools get cold when you use them. On a gas driven turbine, the pressure drops across the turbine, and so does the temperature. That is where the enegry comes from to drive the turbine wheel. The temperature loss repersents an enegry that is transferred to the turbine wheel. My understanding is that on many engines running a turbocharger, actually have a higher pressure in the intake manifold than there is in the exhaust manifold between the exhaust valves and the inlet to the turbine of the turbocharger, under some conditions. This seems impossible, until you remember that not all the heat enegry from burning the fuel in the first place is used in moving the piston. The turbocharger turbine is able to capture some of the formerly wasted energy, and use it to compress the intake charge.
If you design the engine with this in mind, it is possible to use the wasted exhaust heat to do part of the work of compressing the intake air, and free up a part of that power to drive the crankshaft.
On your helicoptor engine example, the increased rotor load on the engine does increase the pressure. It also increases the temperature of the gas, allows for a greater temperature drop, and the greater temperature yields more power to drive the rotor. The temperature also goes way up on the the engine parts.
  #30 (permalink)
Old 08-13-2008, 05:58 PM
Krewat's Avatar
We're arguing the same point.
The temp drop across the exhaust side of the turbo is a by-product of the expansion of the exhaust gas. You're not harnessing the heat to produce energy. Quite the contrary.
Conservation of energy. No Such Thing As A Free Lunch.
Anyway...
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
